DC Sound Lab
Level 6 18 inverted mounting diameter?
I would measure the inside edge of the outside gasket and give the baffle a 3/8ths round over... make sure you leave enough wood to support the weight and there should not be any problems.... Its strange that nobody that has done inverted has posted an exact cut out diameter .... I dont know if you can use the Mounting Hole Diameter of 16.75" for an inverted install.... if anything it will be too small and you can remove more material
  • Who's Online   0 Members, 0 Anonymous, 1414 Guests (See full list)
