BigPimpin91 Posted May 17, 2010 Report Share Posted May 17, 2010 You're missing a pedal. BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
chud Posted May 17, 2010 Report Share Posted May 17, 2010 This is the greatest build of all time. You can't fix stupid Link to comment Share on other sites More sharing options...
omgitscollin Posted May 18, 2010 Report Share Posted May 18, 2010 One of the most mind blowing cars I have ever seen. All the work is immaculent and the attention to detail is unmatched. AlphaDamp CLD Tiles - Get more Sound Deadening with less Sound Deadener Link to comment Share on other sites More sharing options...
robola 46 Posted May 18, 2010 Author Report Share Posted May 18, 2010 I had some rubbish laying around to make something out of. The carbon dustcovers who are behind the wheels, were never completely finished in my opinion. I mean, it was just “plain” and nothing special. Now I was able to put some more time and effort into it, and started milling some aluminum from 3mm thick. First I made a round disc of MDF, pasted the aluminum on it, and milled out the 4 plates. Offcourse this was childsplay, but then we stepped up a level. The meaning is to make a little frame around the carbon, on the outerside from the disc. This may not be too wide, so it wouldn’t look to plumb. Once this was all drawn out on the aluminum, we could get started. The outer border is 7mm thick. The dangereous part is, that it could bend from the heat, or that the mill would cut in. But I thought about this long, and used a lot of WD40, and also I milled away a half mm per time. Here they are, and it all worked out very well, although some polishing will be necessary. This one is already abraded and polished. This time I didn’t do the polishing by machine, just because I didn’t think it would come to a good end. Much do dangereous so hold this to a brush. So I did it by hand, but offcourse, you don’t get the same result as by machine polishing. But they shine a bit Link to comment Share on other sites More sharing options...
robola 46 Posted May 21, 2010 Author Report Share Posted May 21, 2010 I managed to find a way to polish those tiny alu rings with the machine. This is the little plank of MDF I used to mill them. On the outside I screwed a little slat that sticks out a few mm's Made some more little plates. Here you can see how tight it is, and it can't slide or shift somewhere. The 5 plates are holding the piece down. Offcourse I taped some "mush?" on the plates, so I didn't scratch the aluminum. Instead of keeping it against the polishingmachine, I chose to do it with the drillingmachine, and this worked a little bit better as usual. Once this was done, I had to screw the piece loose, and slide the piece a bit. So I could reach the 5 places where the plates were, too. This was the result, and you can never accomplish this by doing it by hand. Here a familiy picture. The aluminium bar that lays on the sanding block, I used to abrade the roundings on the inside. Just turned some sanding paper around it. I get a lot of questions about how many time I put in to these things. Well, this is the first time I kept track of time. I worked on these rings 26 hours. and then I mean: Drawing out Mill the MDF Saw out the aluminum, milling, and ...a lot of milling a little bit of "filing" abrading and a lot of abrading. cleaning and polishing quickly making a set of 4 rings, LOL Link to comment Share on other sites More sharing options...
Trippi Posted May 22, 2010 Report Share Posted May 22, 2010 Man you are back at it again?? U just couldn't sit still huh... ~~~~CHODE FTW~~~~ DC4LYFE Link to comment Share on other sites More sharing options...
chud Posted May 22, 2010 Report Share Posted May 22, 2010 The OP has definitely raised the bar. You can't fix stupid Link to comment Share on other sites More sharing options...
USLESS Posted May 22, 2010 Report Share Posted May 22, 2010 that$ a pritty $ix a$$ build bro my 94 ranger build http://www.stevemead...4-ranger-build/ Link to comment Share on other sites More sharing options...
El1T3Bass Posted May 23, 2010 Report Share Posted May 23, 2010 wana sell you bmw to meh wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic Link to comment Share on other sites More sharing options...
robola 46 Posted May 23, 2010 Author Report Share Posted May 23, 2010 I didnt think so but it was worth a shot. Im still watching though best ive have ever seen in any country Didn't go through all 26 pages but from what I saw... Just Pure Class a+++ What an amazing car. You have pure talent. This is the greatest build of all time. One of the most mind blowing cars I have ever seen. All the work is immaculent and the attention to detail is unmatched. that$ a pritty $ix a$$ build bro THX DUDE's Link to comment Share on other sites More sharing options...
