All Activity
- Past hour
Understood, 12.2 getting spicy, definitely below what the truck needs. When setting gains...HU is full open filters and flat EQ (120Hz LPF..highest setting), SIA2500 has HPF/LPF opened to maximum ranges. After gain is set, HU stays at 120Hz LPF, I tune LPF/HPF on amp with DMM then maybe adjust slightly by ear after that. I never turn up the bass or sub EQs on the HU, only mids/treble sometimes. I never use the Bass Engine on the HU. Battery in DD1 is 4-5 weeks old. I will swap a fresh one in and test. I'll Google up on this and see what I can learn. I have a cheap ($80) Oscilloscope/DMM combo. I understand the limitations the small display has for projecting waves in detail. Also crispy, thank you all the helpful posts you make on here. I've learned a quite a bit from reading replies from you and the other bassheads around here. Cheers
Will these mids be able to take 1500wRMS?
CloudDoesSPL replied to CloudDoesSPL's topic in Mid's and highs
Roger that loud and clear, thanks a lot. - Today
if I remember correctly the SIA is a full bridge amplifier, I don't think the dd1 reads full bridge correctly. something about how the amps work doesn't jive with the dd1. I thought I read something on Facebook about it... idk I could be wrong. now that I'm thinking about it, I don't believe I ever got a clip light when using my dd1 on my SIA3500, although I could for sure hear distortion in the sub
crispy_chick3n replied to CloudDoesSPL's topic in Mid's and highs
the whole "this voltage is this many watts" is not accurate at all. the best way is to match up wattages with amps and set everything clean. I'd recommend finding a different amp or speakers to better suit the other. -
yea, that 12.2 makes my eye twitch a little bit. it's my understanding that the SIA amps are supposed to be ok with lower voltage, but that's getting down there. for sure going to need some electrical upgrades. a second battery will get you by in the meantime. once you get steady voltage I imagine you'll find a clip light with the dd1. for reference, what are your subwoofer and crossover settings look like on the head unit? also how long has it been since you've changed the battery in your dd1?
Could use the DD1+ to get an approximate output voltage to 1000wRMS or no? -
It's a 1500wRMS times two, so it will be a bad time I suppose I'll probably wire them down to what 800wRMS per channel at 4 Ohms, thanks a lot! -
by rms rating you'll be at 1600 watts for the 8 speakers, so it depends how the amp sends its power out. if it is a 1500 watt amp divided between 2 channels then you'll be right in the butter zone. if the amp is 1500 watts per channel, then you're gonna have a bad time -
CloudDoesSPL started following Will these mids be able to take 1500wRMS?
Getting these mids for my doors, 4 of them on each door https://hertz-audio.com/product/car-audio-midrange-spl_show-sv-200-1/ Pairing a korean 1500x2wRMS @ 1Ω amp, will they be able to take it when tuned to 0dB with a DD1+ and crossed at probably 160Hz with a CC1? Thanks guys
Understood. Second sub, big 3, bigger alt, and new box supplies getting ordered today. I've read (on F150 forums) that these trucks stock alternators handle 3k watts pretty well. test tone from tone generator app - silent to full tilt 30hz 13.04V to 12.86V 40hz 13.04V to 12.9V 50hz 13.04V to 12.2V 60hz 13.04V to 12.25V
You don't run a 2500W amp (specially full bridge) on stock electrical, to test this connect a voltage gauge at your amp power terminals, turn up your volume, if you see that voltage drop as you turn the volume up there is for the most part your problem, the other thing is that every 3dB of gain you need twice the power so at 2000W you will be just barely louder than 1000W and to gainthe same 3dB at 2000W you will need 4000W crazy watts, that is why power is not your first option to get loud, cone area is.
Big Tex db changed their profile photo
Howdy. I've recently returned to the car audio hobby. I have some fresh equipment (and some old) that seem to be acting weirdly. 2012 F150 4dr 5.0L (Stock - no big three) AGM battery - One that O'Reillys offers for my pickup (I will return and edit with a brand/specs ASAP) Alpine 172BT (purchased 2019) 1x Skar EVL 12 D2 (New) Sundown Audio SIA2500 (New) Wired parallel @ 1ohm Homemade 2.4cu.ft, 32Hz, L shaped slot port, Sub/Port front facing, ~26 sq.in port area, and appropriate port length calculated from WinISD --- Previously was using a Memphis Audio 1500.1PRX to drive the woofer I'm getting consistent and correct ohm/volt readings thru out the truck and audio system. Headunit is clean at 34/35vol, 40hz -0db SMD tone CD. The only time distortion is showing up during gain tuning is when using the 0db or -5db tones. The -10db and -15db tones show zero distortion all the way to max gain (other than the random blips that show up when turning gain). EQs and Filters are all flat/open/full pass/etc. on the HU and the amp. Sky High Audio bass knob at full tilt. My oscilloscope's readings are consistent with my DD-1's readings. The reason I purchased the SIA2500 was, one I hear they're a quality brand(and I should be able to run two 2ohm DVC subs @ 2ohm @ 2500watts in future), and two I assumed my 1500.1PRX was on the way out when it was also reaching max gain without distortion when tuning to -10db and -15db tracks. The sub gets kinda loud, pretty full sound, pretty deep(I keep my SSF around 27-28hz), but at least clean at full tilt on both amps. But after going from 1500watts to 2500watts, I am noticing no change in performance from the sub. No increase in volume, not reaching any deeper with more strength. I've yet to run into this issue with the handful of subs and amps I've used throughout life. I've never reached full gain on any amps in my life yet. If this helps, my Skar 100.4AB (800 watt) 4way is running my door speakers (Skar TX-65s) without distortion. The gains on them are about mid way, more on board with the "usual." I currently have these tuned to the -5db 1k Hz tone. I say this knowing amp/sub components can react differently from unit to unit. So after burning your eyes out with a wall of text - my goal is to make sure this gain setting will continue to be safe for my equipment BUT MORE IMPORTANTLY I feel I am not getting full performance out of this sub and/or amp(s). Thanks for your time. I'll reply ASAP
- Yesterday
it usually takes a while for newer cars to have info like that online. if the body and interior didn't change from 2022/23 you might try looking those up as there is a better chance the wiring for those will be online. if you go that route I would take everything you see online with a grain of salt and test, test, test to make sure you have the signals you are looking for. I assume you are needing signal wires for the input. if that's the case, the best and probably the easiest way to get it would be from the factory amplifier. GM likes to shove these in the trunk area usually behind some trim panels near the wheel well. I've seen them on both driver and passenger side of the trunk, so it's your guess which to try first. now you'll need to figure out what speakers on the car actually output the bass, usually on these newer vehicles it's the front 2 doors unless it has a factory sub. if it has a factory sub you'll want that signal. if not grab the 2 with the most bass and tap into them. run them to the 4 pin Molex then it's just power, ground, and bass knob if there is one. you won't need a remote turn on as this has signal sense built in so when it sees signal on the input it turns on. here is some wiring from the12volt for a 2018... it's the newest public info out there for an encore, but that doesn't mean its correct. I make no guarantee on if its right or wrong, just putting it here for easier reference Radio 12V Red/Gray + Radio, gray 20 pin plug, pin 1 Radio Ground Black/White - Radio, gray 20 pin plug, pin 11 Radio Ignition (Low Speed GMLAN) Factory Amp Turn-on (MOST Serial Data) Left Front Speaker (+/-) Blue - Brown/Blue +,- Amplifier near rear wheel well, green 16 pin plug, pins 7 - 15 Right Front Speaker (+/-) Yellow - Yellow/Black +,- Amplifier near rear wheel well, green 16 pin plug, pins 6 - 14 Left Rear Speaker (+/-) Green - Green/Black +,- Amplifier near rear wheel well, green 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) White - Blue/Black +,- Amplifier near rear wheel well, green 16 pin plug, pins 4 - 12 Subwoofer (+/-) Green/Black - Blue/Gray +,- Amplifier near rear wheel well, gray 8 pin plug, pins 7 - 3 **** copied from the12volt****
Hi everybody, I recently bought a 2024 Buick Encore GX with the Bose system. I’m looking to install this JL Audio sub combo for some bass. I’m lost on wiring it and have already asked crutchfield and they have zero info. https://www.crutchfield.ca/p_13693330/JL-Audio-ACP108LG-W3v3.html i thought some installers could help with a wiring diagram and do I need a jl audio clean sweep. thank you
that rockville amp isnt doing you any favors there. on that ticket, neither are the e series subs. its all what i used to sell as entry level. (not the rockville... never that) the list i sent you would be worlds louder than anything those e subs can do
rcas
crispy_chick3n replied to hayden b's topic in General Audio - Can't find a category for your question? Ask here.
radio out to dsp. dsp out to bass knob and 4 chan amps. bass knob out to epi. epi out to bass amp. does your dsp not have a bass knob? if it does i would use that over a rca bass knob. just my opinion tho -
there really isn't a best website... I learned a lot from this forum years ago and just started playing with design software. over the years I've learned A LOT by just doing it. a good place to start is with Torres box tuning calculator (there's a free link in enclosures section) and winISD (google has the link for this one) I start with measurements in the car and transfer those into Torres to see where I'm at airspace wise. if you are going sealed then the numbers it outputs there will be roughly what you'll have for airspace. if you are going ported id usually rough in 1/4 to 1/3 extra for port displacement at this point (you can fine tune this later). next is port dimensions. its more of a game trying to balance net volume, port tuning, and sq in of port area (generally shoot for 12-15 sq in per foot of port area as a basic guide) once you have what you like there you can use the cutsheet to build the box if you would like, or you could take it a step further and input it all into winISD to see a few graphs of what your box should perform like. there's a good bit of setup involved with winISD and I'm sure you can find all the info you would need here on the forum using the search bar for winISD. I'm not an expert on any of this by any means, but through the better part of the last 15 years I've gained a bit of knowledge on at least what not to do. experiment and explore with these programs and see what you can come up with. if you are stumped on something post it up with some screenshots and I'll be more than happy to give you a few pointers.
- Last week
TWO $500 Shopping Sprees at www.secondskinaudio.com see our newest SMD post!
New Second Skin soundproofing video on our YouTube channel...get over there, like, comment, and enter to win a $500 shopping spree of soundproofing! https://youtu.be/I7TZTvmzDcA?si=eloR83MgU6f4Atst 1K giveaway details: (2) $500 winners for a Shopping Spree on the Second Skin Audio How to Enter: (1) Make sure you're subscribed to our YouTube (2) Comment on the YouTube video your vehicle build and noise issue Giveaway Terms & Conditions: Each subscribe and comment is (1) entry. So (2) entries max per person. Offer ends in 1 week (6/8/2024) Winners will be announced on 6/12/2024 1K giveaway social 1.mp4
- 1 reply
- 2
i have a bass amp and a voice amp and i want to put a epi center and a dsp and i have a rca bass knob and i am confused on how many rca cables i will need and how to run them all.
hayden b started following subwoofer enclosure designing
what is the best website for designing subwoofer enclosures?
my current setup is 2 sundown E series 12s in a 2.5cu slot port enclosure running on a 2000 watt max rockville audio amp (db12) stock electrical pioneer double din headunit also have a speaker wall above my back seats with 2 rockville marine speakers and a ds18 pro 8” midrange and 2 skar 3.5” tweeters running on a rockville full range amp all wiring for amps is rockville 4gauge and rockville rca
how much air space does this subwoofer need?
this would get down. would even have a bit left over to get a box built and a second battery. if you are feeling spicy you can add some lithium power and rock with the D1 sub at 0.5 ohm... might be a bit much power for that sub at 0.5 ohm. the safe way would be to get the D2 coil config and run it at 1 ohm
