Build 2007 Tahoe Build Thread Pics
i dont see a stock battery under there unless theyre on the other side......
It's like that in my 07 Tahoe. The battery is on the passenger side really close to the firewall.
what do you mean...worn?
there is a stock battery on the other side, 1 optima in the spair battery spot, then another optima in the backon the left side of the subs in the wheel well part of the trunk along with the cap
yes, 1 on the other side, one in the spair battery spot, and another in the back explained above
thanks a lot man!
exactly...saying you have a 07 also, do you like what we did with the amps? basically a free amp rack came with the truck lol
Yep, I'm digging that amp rack. My install won't be as extensive. I'm only going to run one amp. Did ya'll run the power wire underneath the truck or through a firewall? If you used the firewall, then which one did you use so I can copy it :D
