can i get a diagram to wire an amp to a battery in my trunk? Thanks.
Do you already have the battery in your trunk?
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
[bat]
[amp]
k? the positive to positive, the negative to negative, with wires of a proper gauge
run 0g from the front battery positive to the rear battery positive, run the rear battery negative to either a good chassis ground or the front batt negative (and do the big 3)
chassis ground is 10x easier
Team DC
ya
Are you asking how to hook it up to the primary battery or to the amp?
Car
1996 Sable LS
My Build
Truck
Truck Build
+[batt]-===CHASSIS
+[rear batt]-===CHASSIS
|_________|
+[amplifier]-
there, updated diagram, hope it helps
and yes, + to + to +, -'s to -s or ground (which is negative by definition), its called parallel, it keeps everything at a constant voltage.
http://www.bcae1.com/ read through that site if youre going to be doing car audio stuff by yourself, it gives alot of the basics, terminology and formulas you use with electronics/acoustics/car audio
Edited by raytard
Team DC
so something like this? wiring.jpg id only need a fuse between the 2nd batt and the amp right?
You also need to ground that amp either to chassis or to the negative terminal on the battery in the trunk. You should also fuse the 1/0 wire that goes from hood to trunk. Put a fuse within 18 inches of the battery on each end of the cable. so one fuse under the hood and one under the trunk. That way if that cable gets pinched and you ground that baby out, it won't start your car on fire.
97 Maxima SE
Bunch of shit going in, check out the build
is this better?
  • Who's Online   0 Members, 0 Anonymous, 574 Guests (See full list)
