Batteries C&D Technologies And GNB
Alright so I get these batterys locally and they are bad ass... Me and my buddys been using them for a while and love them so I thought i'd sell a few... I also get a bit of a deal and figured I'd pass that on as well. They are the size of like a hc1800... They are all AGM non-spillable batteries of course. They are all slightly used, few scratches or whatever.. All charged, load tested, and just sitting here waiting for use...
Sacramento CA Area Pick Up Pm Me... Also Pm me for multiple deals of course. Will take Offers and some Trades... So let me know...
Oh and also Refs.. I forgot but umm got a few on ca.com and then tons local... zfrerichs just picked some up, umm me, 99vic, and loganberry been running some for a few... Ummm know quite a few guys here personally and done deals such as alarms, boxs, iunno but ForEvrBumpn, B Slaps Yo Mama, civicman, colt 45, Noobtastic, zfrerichs, ect.. Team Nor*Cal Bass - 99vic, Loganberry, Ipod, thehoe92 Also got 200 or so 100% feedback on ebay and 99vic already said he'd put his superseller 100% feedback on the line for me as he will be the one getting a little discount on shipping the batts for me..
Prices Shipped Lower 48(Unless your zip like crazy high for some reason) And Also Open to Trades
C&D UPS12-270FR (75AH) - 160 Shipped
GNB Splinter (75AH) - 165 Shipped
NPX-150R (40AH) - 90 Shipped
C&D Technologies Dynasty High Rate Series UPS12-270FR
Valve Regulated Lead Acid Battery
for UPS standby power applications
12V 75 AH @ 20 hr rate,
12V 282 watts/cell @ 15 min. rate
57lbs
Dimensions = 10.27"L x 6.82"W x 8.82"H
FEATURES
Flame-arresting one-way pressure-relief vent for safety and long life.
Thermally welded case-to-cover bond to eliminate leakage.
Absorbent Glass Mat (AGM) technology for efficient gas recombination of up to 99% and freedom from electrolyte maintenance.
Computer-generated grid design optimized for high power density.
UL-recognized component.
Multicell design for economy of installation and maintenance.
Can be mounted in any orientation.
Not restricted for air transport – Complies with IATA/ICAO Special Provision A67.
Not restricted for surface transport – Classified as non-hazardous material as related to DOT-CFR Title 49 parts 171-189.
Computer designed lead, low calcium alloy grid for minimal gassing and ease of recycling.
Case and cover available in both standard and flame retardant polypropylene.
Flame retardant polypropylene case and cover compliant with UL 1778 (optional)
GNB Sprinter S12V285F
12V 285WPC @ 15 min. rate, 1.67vpc
Features
8 year design life @ 25 degree C
3 year replacement Warranty
Absorbent Glass Mat Technology, AGM
No restrictions for Ground/Air Transport, non spillable battery
Specifications
Dimensions = 10.25"L x 6.85"W x 8.8"H
1300 ca
1130 cca
75 ah
63 lbs
NPX-150R
Enersys formally Yuasa NPX-150R battery are designed using proven gas recombination technology which removes the need for regular water addition by controlling the evolution of hydrogen and oxygen during charging. Gas recombination provides the user with freedom to use lead acid batteries in a wide range of applications.
Features & Benefits
• Design Life: 3-5 years @ 25ºC(77ºF)
• UL recognized
• Approved for shipping as non-hazardous, non-spillable
• Operates in any position
Applications
• Emergency Lighting
• General Electronics
• Medical
• Mobility
• Security
• Uninterruptible Power Supply
Technical Features and Benefits
Construction:
• The construction and sealing techniques of the Genesis NP battery guarantee leakproof operation in any position with no adverse effect to capacity or service life.
Electrolyte Suspension System:
• All Genesis NP batteries utilize an electrolyte suspension system consisting of a high porosity, glass fiber material which in conjunction with plates, totally absorb and contain the electrolyte. No silica gels or any other contaminants are used.
Gas Generation:
• Genesis NP batteries incorporate a built-in design that controls gas generation and induces recombination of more than 99% of gases generated during float usage.
Maintenance Free Operation:
• There is no need to check specific gravity of the electrolyte or add water to Genesis NP batteries during float service life. In fact, there is no provision for this type of maintenance.
Low Pressure Valve Regulated System:
• All Genesis NP batteries are equipped with safety release valves, designed to operate between 2 and 5 psi and automatically reseal. Hence, there is never an excessive accumulation of gas within the battery.
Heavy Duty Grids:
• Heavy duty lead calcium tin alloy grids provide an extra margin of performance and service life in either float or cyclic applications, even after repeated over discharges.
Cyclic Service Life:
• More than 1000 discharge/recharge cycles can be realized from Genesis NP batteries, dependent on the average depth of discharge.
Float Service Life:
• Genesis NP Series batteries have an expected life span of 3 to 5 years in float service applications.
Self Discharge - Shelf Life:
• The self discharge rate of the Genesis NP series at room temperature is approximately 3% of rated capacity per month.
Operating Temperature:
• Genesis NP Batteries may be operated over a broad range of ambient temperatures.
Deep Discharge Recovery:
• Genesis NP batteries recover their capacities even after repeated deep discharges.
Specifications
Chemistry Lead Acid
Voltage 12
Capacity 40,000 mAh / 40 Ah
Rating 480 Whr
Length 7.76 inch / 19.71 cm
Width 6.50 inch / 16.51 cm
Height 6.89 inch / 17.50 cm
Color Gray
Weight 34.2 lb / 15,512.78 g
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Also idea on how they are shipped with tracking and insurance..
Posted Image
Posted Image
Posted Image
Posted Image
Passport Build Here
trades...
got a zapco preamp
audio control 6xs
what else are you trying to get?
Id like to have 2 more of those batts.
trades...
got a zapco preamp
audio control 6xs
Donno if I need a preamp but damn those zapco's are nice.. But we can definatly work something out probably.. I'll shoot you pm ray..
Will these batteries handle 1500 watts or over as a main battery?
As a main batt I havn't done just 1.. Always done 1 up front and 1 in back.. With that it handles my sundown saz1500 like nothing.. 13.4 drops 13volts if I let it bang for a few mins at idle...
Mabie ask forevrbumpn or zfrerichs.. They both only have 1 as starter battery as of right now but I donno if they running any amps or anything..
Passport Build Here
i need batts for the benzo
Also didn't add what i'm really looking for in trade is another sundown 1500.. Other then that just offer :D
Passport Build Here
Bump this up got the same batterys available and also the big 134ah ones ARE BACK IN STOCK probably about 15 of them.. Wanna try to keep it local because shipping 100lb batts suck so PM ME Older pics but same batts
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Passport Build Here
ttt
Passport Build Here
Do you still have the Batts. Witch would recommend for my set up Kenwood KAC-1023 and 1 L715?
Thanks
2 15"s Re-coned with a Custom re-cones with DD 9500 coils, Rockford Fosgate T1500-1bd, Designated Aux. 190 amp Alt@ 15.5 volts, Duel High Rate Aux. Batts. Doing 143+'s (current box and subs haven't been metered), 1st place in 129.9 Bass Race and a 2nd and a 3rd in NW DB Drag in the last two shows. Only gone two 2 show total thought, so not to bad
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
