FS: Diamond, Kicker, ID, Infinity, Powerbass, Cerwin Vega, Pioneer, RE
I have a bunch of stuff for sale cheap. All of it is brand new in the box. All prices are shipped and each if there are multiples. If you order more than one thing I will cut you a deal. If you have any questions just ask. I have plenty of refs. Not looking for any trades and it is first come first served.
Diamond Audio
(2)D1 10 Dual 4 ohm 50
(2)D1 12 Dual 4 ohm60
D1 250.2 110
D1 400.1 130
Pioneer
GM-7300M 360x1 at 2 ohms CEA 100
GM-4300F 40x4 at 4 ohms CEA Sold
TS-G1342R 5.25 Coax SOLD
Kicker
(2)DS 400 4" Coax 30
(2)C15 Single 4 ohm 75
DS 6939 6x9 3 way 50
Infinity
4012i 4" Coax Sold
602si 6" Coax Slim Sold
Cerwin Vega
HED 4.0 4" Coax 35
HED 69 6x9 3 way Sold
Powerbass
(2)S-652 6.5" Coax 20
ASA 300.2 75x2 @4, 150x2 @2, 300x1 @4 80
Image Dynamics
CTX57 5x7 coax 95
Resonant Engineering
RE 8 Dual 4 Ohm 45
RE 10 Dual 4 Ohm 55
Posted Image
* Type: RE Audio RE10 Dual 4 Ohm Coil Subwoofer
* Max Power Handling 350W
* RMS Power Handing 175W
* Mica Filled Poly Cone
* Santoprene Rubber Surround
* Pressed Steal Basket
* High Temperature 8 Layer Copper Voice Coil
* FEA Optimised Motor Structure
* Single Heavy Duty Magnet
* Linear Conex Spiders
* Foam Gasket
* Mounting Depth - 5"
* Mounting Hole Diameter - 9.125"
* Overall Diameter - 10.125"
* Bolt Hole Circle - 9.75"
* Motor Width - 4.875"
* Motor Depth - 1.5"
* Basket Depth - 3.5"
* Displacement - 0.09 cu. ft.
* Weight - 6.5 lbs
* Electrical Q Value -Qes: 0.39
* Mechanical Q Value -Qms: 4.37
* Total Speaker Q Value -Qts: 0.36
* Free Air Resonance -Fs: 21.5 Hz
* Equivalent Compliance -Vas: 75.6 liters
* One-Way, Linear Excursion -Xmax: 12 mm
* Efficiency -SPL 1W/1m: 84.7 dB SPL
* Effective Piston Area -Sd: 322 cm^2
* DC Resistance -Re: 3.2 ohm
* Nominal Impedance -Znom: Dual 4 ohm
* Thermal Power Handling -Pe: 175 W
* Force Factor -Bl: 15.4
is that 3 sets of power bass speakers or 3 speakers?
and i think u might need to put pics of everything with screen name n what knot, kinda a rule here
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
cash sent :D , bump for some more stuff FS
