TRAVELING PA SYSTEM (3) 12's and (10) 5.25's (2) 1" Tweeters.
Just Order (10) of these GRS-5PF-8 5.25" Drivers , and I orderd 2 Blue 25LED strips to go on the box for the fact that LED lighting and Music go together well. I also have 2 1" Zues Tweeters going into the top of the towers,and (2)Pyle Pro 3x3 Horn Super Tweeters . With the towers being 4 ft tall X 10.5" Deep X 7.5" Wide. With PVC tubes downfiring at 2" x 18" each tower. With floorpegs and it should tune the bass pretty low and make the voice Nice and loud with the right EQ ing. The Amp for those will be A Kenwood KAC5400 Reciever 160w RMS @ 8 ohms x 2 both towers have 5 8 ohms speakers I dont know what the Load will be when there wired but it should be okay... The amp will handle @ 2 ohms on CVX 10's so... should handle the load without clipping to much if the 120HZ and Lower is Cut out so the amp doesn't DEMAND to much. And then get hot.
SMD FTMFW!!!!!!!![ VIDEO REVIEW OF GRS 5PF-8's
2003 Dodge Intrepid 3.4L v6 Stock Alternator 12.5 V all day.
DREAM SYSTEM IN PROGRESS> STILL JUST A PLAN....
(2) Custom Ascendant Audio Mayhem 15's 6th order walled
(1) (4)JL Audio 1000/1 V2
(4) JL Audio 500.4
(5) XS Power D3100 (1) XS Power D1200
(1) Mechman Alternator 400+ AMPs
(8)Tang Band W8-1772 8" Neo Drivers
(8)Tang Band 25-1166SJ 1" Neodymium Tweeters(2) in each pillar
(4) Dayton PS180 6.5" Neo Full Range Drivers in Rear Shelf
(4) Eminence Delta Pro-8A 8" Midrange
WENT TO RE BOX DESIGN AND GOT THIS IT LOOKS PRETTY COOL! LOOKS LIKE EXACTLY WHAT ILL BE MAKING FOR L PORTS! IF I DECIDE TO... THAT WOULD BE SICK... The tuning here is 28HZ ! @ 21.25" inches of woofer cone area with 2,5mm of X-max
The Frequency of the woofers is 70-100 HZ, so If I should tune the port that way instead someone let me know, cause I want the cleanest bass I can get ! I assume a good amount of port area will sound very nice and smooth.
(4) JL Audio 500.4
Just Order (10) of these http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=292-405&scqty=10 , and I orderd 2 Blue 25LED strips to go on the box for the fact that LED lighting and Music go together well. I also have 2 1" Zues Tweeters going into the top of the towers, With the towers being 4 ft tall X 10.5" Deep X 7.5" Wide. With PVC tubes downfiring at 2" x 18" each tower. With floorpegs and it should tune the bass pretty low and make the voice Nice and loud withthe right EQ ing. The Amp for those will be A Kenwood KAC5400 Reciever 160w RMS @ 8 ohms per channel. 2 channels. both towers have 5 8 ohms speakers I dont know what the Load will be when there wired but it should be okay... The amp will handle @ 2 ohms on CVX 10's so... should handle the load without clipping to much if the 120HZ and Lower is Cut out so the amp doesn't DEMAND to much. And then get hot.BUILD PROGRESS
SMD FTMFW!!!!!!!!
The Frequency of the woofers is 59 HZ, so If I should tune the port that way instead someone let me know, cause I want the cleanest bass I can get !
SPEAKERS ARE HERE THE GRS 5.25" MIDS ALL WORK AND SOUND BEAUTIFUL, Cant be more happy, very awesome speakers, the Pyle super tweeters kinda suck ass, they have different Frequency Responses as well... weird but not a shock still, I have my towers built but I NEED A ROUTER TO CUT HOLES for speakers/ Terminals, Port. youtube.com/gfhnk
(4) JL Audio 500.4
SMD FTMFW!!!!!!!!
(4) JL Audio 500.4
I will Get pics Uplaoded ASAP. these 5Pf-s sounds smooth, and get very loud and clear. running at 4-8 ohms. Under that and they donut do well.
(4) JL Audio 500.4
HOW DO I POST PICTURES!!!!! FROM FACEBOOK?
(4) JL Audio 500.4
I HAVE LOTS OF PICS IN HIGH DEF 12.5 MP AND I WANNA UPLOAD THEM BUT I DONUT KNOW WHAT URL TO GO THROUGH OR WHATEVER, Other Forums dont use the same thing.
(4) JL Audio 500.4
