so im thinking its cuz im not using a vise
but when i feed the solder into the terminal it doesn't start to puddle at the top and it starts to run down into the wire and melt the jacket.
so why is this happening? because im not using a vise?
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
x2 same thing happened to me. I didn't use a vice either.
so did you end up getting it to work with a vise? or how did you fix it
You gotta move the heat around I usually start heat at the top and move it to the bottom then cool the bottom and fill to the top.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
it happens, you just gotta get the hang of it really, i did a wire the power wire in my car with pliers and 2 batterys stacked on top of eachother and the pliers between them, like bum said, you gotta move the heat around, cuz if you keep direct heat on it its just gunna melt the jacket
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
ive never used a vice...
make sure to heat the whole terminal and dont push a foot of solder in the terminal at a time. push in alittle, and keep doing that till its filled
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
^That is beautiful.
Like they said, it's about heat and not using to much of it.
You have to wick solder into the wire then let it cool enough
to form a little plug so that the next push of solder will go
on top of it rather than just filling up the whole cable.
It takes a little practice before anyone is a pro at it.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
^That is beautiful.
Thanks, but i actually don't even like how that one turned out. Just doesn't look right to me. And that was the day that i spent about 5 straight hours just cutting wire and practicing terminals. Wasted like $25 that day, but i think it was worth the experience.
Practice practice practice.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
  • Who's Online   0 Members, 0 Anonymous, 589 Guests (See full list)
