Mattintc10 Posted February 7, 2011 Report Posted February 7, 2011 Well ever since i saw meade cut out a portion in his tahoe for the batteries i went on a serious thinking streak. Is it at all possible in some vehicles under the back seat cut out a portion build a small compartment in there and use that piece of metal you cut out to make a lid. But of course use some kind of metal to make the compartment and weather seal it and dead it and what not.
hdorre Posted February 7, 2011 Report Posted February 7, 2011 Depends how much space (depth) you have, your experience, and tools. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Mattintc10 Posted February 7, 2011 Author Report Posted February 7, 2011 Depends how much space (depth) you have, your experience, and tools. yeah thats what i thought.
osamio Posted February 7, 2011 Report Posted February 7, 2011 Well ever since i saw meade cut out a portion in his tahoe for the batteries i went on a serious thinking streak. Is it at all possible in some vehicles under the back seat cut out a portion build a small compartment in there and use that piece of metal you cut out to make a lid. But of course use some kind of metal to make the compartment and weather seal it and dead it and what not. You'd need some welding experience, and probably an angle grinder with a cutting wheel... Then yea, build up a box, shouldn't be too difficult, weld it on, or if u can't do that, bolt it on with L brackets... make sure its water tight.... but under the back seat is usually the gas tank...in most cars... Just saying. I'm not sure what vehicle u have but i just thought i'd mention that. 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
Mattintc10 Posted February 7, 2011 Author Report Posted February 7, 2011 Well ever since i saw meade cut out a portion in his tahoe for the batteries i went on a serious thinking streak. Is it at all possible in some vehicles under the back seat cut out a portion build a small compartment in there and use that piece of metal you cut out to make a lid. But of course use some kind of metal to make the compartment and weather seal it and dead it and what not. You'd need some welding experience, and probably an angle grinder with a cutting wheel... Then yea, build up a box, shouldn't be too difficult, weld it on, or if u can't do that, bolt it on with L brackets... make sure its water tight.... but under the back seat is usually the gas tank...in most cars... Just saying. I'm not sure what vehicle u have but i just thought i'd mention that. Most modern cars the gas tank is in that location although some older vehicles actually have the gas tank under the trunk .
