Fun idea i had but i need some help
so my stereo in my room is complete crap now that my velodyne subs gone so i was looking into new subs and i had this idea
i want to take 6 of theese http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=295-486
and put and take 2 boxes and put 3 in each but problem im having is what amp should i get? i cant find a amp that will put out 250 watts on each channel and the subs are dual 4 ohm and what should i wire them down to?
and i am able to build a box but idk about ports or size i was thinking just use 2 plastic tube ports on each box at the bottom of it like this http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=143&CFID=8856635&CFTOKEN=66636522 but i wanted to get some expert advice sense im 16 and never built anything like this and im also a noob to audio lol
HEY BRO! Your going the right way. I would get 4 of those subs, or 6 if you must! lol, But ya in each box you should go the easiest way, and tube ports arent exactly easier. You should assemble 2-3 boxes Just like this
2003 Dodge Intrepid 3.4L v6 Stock Alternator 12.5 V all day.
DREAM SYSTEM IN PROGRESS> STILL JUST A PLAN....
(2) Custom Ascendant Audio Mayhem 15's 6th order walled
(1) (4)JL Audio 1000/1 V2
(4) JL Audio 500.4
(5) XS Power D3100 (1) XS Power D1200
(1) Mechman Alternator 400+ AMPs
(8)Tang Band W8-1772 8" Neo Drivers
(8)Tang Band 25-1166SJ 1" Neodymium Tweeters(2) in each pillar
(4) Dayton PS180 6.5" Neo Full Range Drivers in Rear Shelf
(4) Eminence Delta Pro-8A 8" Midrange
