lombo352 Posted February 9, 2011 Report Posted February 9, 2011 I plan on putting 2000 watts in my truck and using kinetics 2000watt batt...this battery will be hooked up in the rear and i will still have the other battery to run the truck...will this battery charge just like my stock battery? ive never run dual batterys before so im kinda clueless...thanks for any help Quote 96 Ram Build
osamio Posted February 9, 2011 Report Posted February 9, 2011 I plan on putting 2000 watts in my truck and using kinetics 2000watt batt...this battery will be hooked up in the rear and i will still have the other battery to run the truck...will this battery charge just like my stock battery? ive never run dual batterys before so im kinda clueless...thanks for any help How are you planning to wire it? You can do a run of 0 gauge wire from the + on the batt under the hood all the way back to the kinetic, and then ground the kinetic to the frame.. OR you can run a 0 gauge wire from your alternator to the kinetic in the trunk and ground it to the frame. Both ways will allow it to charge from the alt. Do u have the big 3 done though? Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
lombo352 Posted February 9, 2011 Author Report Posted February 9, 2011 I plan on putting 2000 watts in my truck and using kinetics 2000watt batt...this battery will be hooked up in the rear and i will still have the other battery to run the truck...will this battery charge just like my stock battery? ive never run dual batterys before so im kinda clueless...thanks for any help How are you planning to wire it? You can do a run of 0 gauge wire from the + on the batt under the hood all the way back to the kinetic, and then ground the kinetic to the frame.. OR you can run a 0 gauge wire from your alternator to the kinetic in the trunk and ground it to the frame. Both ways will allow it to charge from the alt. Do u have the big 3 done though? yeah i just finished the big 3 Quote 96 Ram Build
osamio Posted February 10, 2011 Report Posted February 10, 2011 (edited) I plan on putting 2000 watts in my truck and using kinetics 2000watt batt...this battery will be hooked up in the rear and i will still have the other battery to run the truck...will this battery charge just like my stock battery? ive never run dual batterys before so im kinda clueless...thanks for any help How are you planning to wire it? You can do a run of 0 gauge wire from the + on the batt under the hood all the way back to the kinetic, and then ground the kinetic to the frame.. OR you can run a 0 gauge wire from your alternator to the kinetic in the trunk and ground it to the frame. Both ways will allow it to charge from the alt. Do u have the big 3 done though? yeah i just finished the big 3 Well, that wire that u have running from the alt to like, what is that a fusebox? and the batt + is connected to the same fuse box thing? The alternator + can go directly to the battery +...even if the stock alt charge wire did not, you can always add the one directly from the alt to the battery IN ADDITION ALSO there should be a 0 awg wire running from the Engine block, to the frame..it should be the same spot u used to ground the battery... AND that ground point needs to be sanded off and cleaned before u attache the wires there. Edited February 10, 2011 by osamio Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
lombo352 Posted February 10, 2011 Author Report Posted February 10, 2011 (edited) Yes i did ground the engine block to the frame...its on the other side of the engine bay, you just cant see it in the pic...and as for the alt wire going to the fuse box it has a 130a fuse there and ive seen people saying you should fuse it and since it was factory fused i just let it be....am wrong in doing that? i thought it would be smart to fuse that line to the alt... and of course i sanded down to bare metal on all connections Edited February 10, 2011 by lombo352 Quote 96 Ram Build
osamio Posted February 10, 2011 Report Posted February 10, 2011 (edited) Yes i did ground the engine block to the frame...its on the other side of the engine bay, you just cant see it in the pic...and as for the alt wire going to the fuse box it has a 130a fuse there and ive seen people saying you should fuse it and since it was factory fused i just let it be....am wrong in doing that? i thought it would be smart to fuse that line to the alt... and of course i sanded down to bare metal on all connections No you are fine with the fuse, It just depends on how much power you are going to be drawing with your amps. Like me personally, I left the factory connection in place.. completely untouched. and added an ADDITIONAL alt charge wire with my own in-line anl fuse. If you are confident in the conductivity/gauge of the stock fusing, then you're fine. but I personally added my own as opposed to replacing stock. In fact i did that with all of the big 3. I added additional runs without touching the stock ones. So did u decide which way to wire your battery? Edited February 10, 2011 by osamio Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
lombo352 Posted February 10, 2011 Author Report Posted February 10, 2011 Yes i did ground the engine block to the frame...its on the other side of the engine bay, you just cant see it in the pic...and as for the alt wire going to the fuse box it has a 130a fuse there and ive seen people saying you should fuse it and since it was factory fused i just let it be....am wrong in doing that? i thought it would be smart to fuse that line to the alt... and of course i sanded down to bare metal on all connections No no your fine with the fuse. Okkk I didn't know u had a fuse there. I couldn't see it in the pic. I thought u were going to the factory fuse box, like the stock location...and i was thinking the stock fuse/wiring would be much to small for a high current wire. but you've done it perfectly then. So did u decide which way to wire your battery? I read the faq's at kinetik site and they say to wire both + and - from the front batt to the rear batt terminals.... im guessing i can get away with just the + from the front batt to the rear...i dont like the idea of wiring straight from the alt to the rear... it will be 1/0 of course Quote 96 Ram Build
dugee81 Posted February 10, 2011 Report Posted February 10, 2011 personally i would not run the wire through the fuse box.... use your own fuse block. 300 amp fuse on each end of the + from battery to battery. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
osamio Posted February 10, 2011 Report Posted February 10, 2011 Yes i did ground the engine block to the frame...its on the other side of the engine bay, you just cant see it in the pic...and as for the alt wire going to the fuse box it has a 130a fuse there and ive seen people saying you should fuse it and since it was factory fused i just let it be....am wrong in doing that? i thought it would be smart to fuse that line to the alt... and of course i sanded down to bare metal on all connections No no your fine with the fuse. Okkk I didn't know u had a fuse there. I couldn't see it in the pic. I thought u were going to the factory fuse box, like the stock location...and i was thinking the stock fuse/wiring would be much to small for a high current wire. but you've done it perfectly then. So did u decide which way to wire your battery? I read the faq's at kinetik site and they say to wire both + and - from the front batt to the rear batt terminals.... im guessing i can get away with just the + from the front batt to the rear...i dont like the idea of wiring straight from the alt to the rear... it will be 1/0 of course I've seen it all three. If kinetik says run the + to + and - to - then i'd do that. I personally ran a run of 0 gauge to my stock battery from the alt, then to my stinger battery, and two runs of 0 gauge from each battery - to the chassis. Its really the same thing.. they're paralleled either way. Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
osamio Posted February 10, 2011 Report Posted February 10, 2011 personally i would not run the wire through the fuse box.... use your own fuse block. 300 amp fuse on each end of the + from battery to battery. x2 i edited my post to say that. when he said he had a 150 amp fuse i didn't know he meant the stock fuse, i thought he added a fuse block in that spot. then i realized he meant the factory fusing. So ya, i'd use ur own fuse block.. Quote 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
