Big 3 runs!?
Hello,
I am doing a 5000 watts rms build in my Hyundai Tiburon. Check out this link for what I am all using.
I am just getting started with the build and am going to start with the big 3. I am familiar with what I must do to perform this. Now would it be a good idea to do 2-3 runs from the alternator + to the battery + for less resistance? And may I also do multiple runs with the grounds? Or isn't it necessary?
I ordered 100' of Stinger HPM 1/0 power wire off of darvex and should have plenty to go around my vehicle. I am already going to do 3 runs from my front battery to my back battery and then 2 runs from the 3rd battery to the amplifier.
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
3 runs i think is a little over kill for 5000w but to each his own. It wouldnt hurt anything thats for sure but i you ever go bigger to you already have it.. Im running around the same wattage too but i have 2 for positive and two for negative back to the front. Are you just doing 3 for power and no ground back?
-----SELLING EVERYTHING----
2 DC sound labs 3.5k's (still avail)
2 HDC312A D1's (still avail)
5 XS Power Batteries (1 d3400 and 1 d1200 left)
4 runs of knukoncepz 0 gauge (have all the wire still)
DC power 270XP alt (sold)
RF T1 6.5 components (both sold)
Powerbass XAX 4160 (still avail)
Custom built box 4.75^3 tuned 34hz (still avail)
yeah I'm going to do 3 for power, and actually good thing you brought it up because I totally forgot about running the ground back. I heard there's a pretty big advantage of doing it! Can you explain to me where that run starts and ends?
And my original question, is there any point in doing more than one run for a ground? For example the battery (negative) to ground and also the engine block to ground. Would this prove to be any benefit?
153 at 23hz
Yeah definitely will prevent huge voltage drops with you running 5000 watts. Let me tell you how i did mine since are setups are similar. I have two dc 3.5ks and i have a 270xp dc alt and i only have 1 run of knukonceptz kollassis flekz because its rated for over 300 amps. If you had a 350 amp alternator i would run two 0 gauge wires to the battery but one should be fine with anything less with the right wire of course. Then i have 4 runs of 0 gauge from the front battery back to my battery bank in the trunk( 2 pos and 2 neg). I also run two engine grounds from the block, one to the battery and on to the frame for shits n giggles. It never hurts to have an extra ground or two, electricity takes the path with the least resistance anyways.
Oh and to run the wires, you just run from the pos and negative from your front battery to the back positive amd negative of your back battery. Amd if you have multiple batteries in the back you just go to one battery but you want to wire all the batteries in parallel (all positives to positives and all negatives to negatives)
  • Who's Online   0 Members, 0 Anonymous, 1656 Guests (See full list)
