XS Power
For some reason the 2010 is not listed, but the 09 3.5l used a Group 24F. The D2400 will be the same physical size, but the posts are reversed, which is no big deal if you are going to upgrade your wiring. Even if you do not upgrade your wiring all you have to do is extend the cables, which is very easy. Just check and see if it has a Group 24F in the 2010 and if so the D2400 will do the job for you.
