Question? Is It Possible To....
Guest MegaloManiac
usually mono block amps arent designed for anything higher than sub notes as far as quality goes.
not possible.
if the amp has abuilt in low pass filter it will only reproduce those freq's there is no way yo bring back freq's that have been filtered out.
there is quite a few mono block amps that are full range that WILL work, hell even hp filters that go all the way up to 500hz HP, Ive seen many. Just usually class D amps are like 10-250hz Infact in pro audio, and homeaudio, mono block amps IS the way to go .. Want 7 channels with a subwoofer, do 7 150 watt mono blocks, and 2 -1000watt mono blocks for the subs. You just use a pre amp to controll everything. In the car audio world, maybe a RF 360.2
thank you
As long as the amp will do full range(no x-over)and you use a external x-over,you will be fine...what are ya thinking,one for the left mid,one for the right mid....something like that???
