Question? Is It Possible To....
there is quite a few mono block amps that are full range that WILL work, hell even hp filters that go all the way up to 500hz HP, Ive seen many. Just usually class D amps are like 10-250hz Infact in pro audio, and homeaudio, mono block amps IS the way to go .. Want 7 channels with a subwoofer, do 7 150 watt mono blocks, and 2 -1000watt mono blocks for the subs. You just use a pre amp to controll everything. In the car audio world, maybe a RF 360.2
thank you
As long as the amp will do full range(no x-over)and you use a external x-over,you will be fine...what are ya thinking,one for the left mid,one for the right mid....something like that???
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
