in a suv is it better to make a wall for your subs or put the subs facing up with the port going towards the back or is there somthing better than those two opitions. also if u go with a wall does it need to be completely sealed off from the back of the car?
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
yes a wall needs to be sealed off hence the term "wall". if you are willing to give up all of your room and rear view capability then ya walls are some of the loudest but if thisis for a daily driver then personally id go sub up port back
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
just wondering if u went subs foward port foward but it wasent completely sealed off from the back it wouldnt be louder then subs up port back because it just seems like it would be louder if they wre facing foward not saying your wrong i was just wondering
"SilveradoGoesBang"
2 FI BTL 18's
CT Sounds 7k
Iv seen db tests of subs back port back vs subs front port front and you lose dbs. Kinda makes sence and kinda doesn't. A wall fully sealed from the back is making it a more compact space so your going to get more air movement (well built I may add) due to such a small space. If its just front not sealed from the back its still got all that room in back to play around with.
04' Chevy Blazer
-Kenwood KIV-BT900, Infinity Kappa 462.9cfp's, Rockford P1653's, Subs... Ridin Stock-
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
