Fi Car Audio
Wanting to try 2 BL 18's and will have about 1600wrms going to each sub. Is that too much? if not, which options should i select for them to perform well with that much power. It will be a daily beater/bass racer..box will probably be around 10 cubes net crx style with about 150 sq inches of port if this helps at all.
2004 Ford Explorer Limited
Mechman 270 Amp alt.(6)Sundown SA-10'sIncriminator Audio 40.1(2)Stinger SPV-2150'sAll Knu Flex Wire
1600 is pretty much perfect for those run all the options and id drop the port area probably to avbout 120 maybe 130sq in
cool i appreciate the feedback.
Will i notice a big difference in output by switching to 18's? I was running 2 DD 3515's off the same power in a 8.5 cu ft box tuned to 34hz with 150 sq. in. of port..and it absolutely slammed, best score i did with that setup was a 147.9 @ 38hz
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
