When setting my gains and head unit and stuff, What do I need my EQ's set at? and do I need to check my Ipod (and other inputs) for clipping? And where would I find a good reliable frequency disk?
Thanks in advance!!!
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
too lazy to answer...
Don't even bother posting then -__-
EQ should be set flat (zero).
iPods should be checked for clipping too
Realm of Excursion has test tones.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
how do you check ipod for clipping?
Get a 3.5mm cable with two "male" ends. Now you would check clipping the same way you'd check in on an RCA B)
LMFAO so true
:blush:
Right on! That helps a lot. Is there going to be an accuracy difference if I use the test tones off my iPod then to set up my whole system?
What is a good frequency to check the iPod at as well? And does it matter what frequency/DB to use in this instance?
Theoretically there shouldn't be a difference
LMFAO so true
:blush:
Thanks! This helps a lot!!!
No problem :)
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 734 Guests (See full list)
