2002 Caddy (8) Fi Btl 18's (2) Rockford T15k's and TONS more! Ipad Air 2 In Dash Page 16
Ok well most of the box is 2 and 3/4" thick now. I just need to take out the front seats and get a little more comfortable so i can start glassing the inside up.
There is already hundreds of dollars in lumber.........why not a little more :D
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Follow my Tweet (Twitter)
now i know youve already seen the opposite side, but dammit this was half a days work and i got glue all over my hands that wouldnt come off on a Saturday nite so i deserve to post it. :D Anyway here is a little more progress.
Posted Image
took out the front seats and center console.....now i can FINALLY work on the front of the box. I couldnt hardly get to the front at all with the seats in but now im all good!
Posted Image
Posted Image
Posted Image
Posted Image
Knocking off the excess glue, resin, and anything else that may be poking out :D
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
here is a few pics....
if your a noobster, you will soon learn that cardboard is your best friend. I just happened to have a large piece from the hoop i got for my sons....
Posted Image
Posted Image
Posted Image
heres a scratched in "hint" of where the port wil be and how big it is going to be too.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
1 port in the other tomorrow...i totally planned on a Squaro Port but since the flare is so big on those, i couldnt fit it. I already had to reduce the port to 144sq in. on each side from the 200 i planned so i didnt want to use an even smaller port just to get a flare on it. Anyway i thru a fat Round Over on it inside and out so that is gonna have to be flare enough :D
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Before i start thinking about the face i needed to reinforce the front section of the bottom of the box. It is where the cargo area steps down and creates a cavity. I already have some 6 x 6 blocks holding it up and glued in place so i just added some more 2x4's to make it rock solid. Oh i still havent gotten to the glass yet :D
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
now 2 more 2x4's under the front lip to fill in the last of the void..plus it gives me mad space to fasten the front pieces too :)
Posted Image
Posted Image
a second one for a little more strength
Posted Image
here is the port install....
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
it isnt fastened on there yet, much like the rear pieces, these wont go on permenently until i get done glassing the inside. I need easier access :D
Posted Image
Posted Image
Posted Image
Ok this will be hard to explain......now i need to route the pieces that surround the middle "chamber" but i have to "turn the corner" with the router instead of rounding i off.....ummm i dont know how to explain. Anyway i took it all out, nailed it to a few pieces of wood that acted like a jig to hold it in place. Then i was able to route the middle rectangle without messin it up. After that i just remove the pieces of wood holding it together and bam its done. No way to route it in the vehicle so this was the only way i could think of.
Posted Image
Posted Image
Posted Image
Posted Image
these peices are NOT fastened in place just sitting there, they will come out before i start glassing and bracing the inside of the box so i can have easier access. This is the direction im goin with it though :D
anyway here are a few pics of tonites work. I am basicly doing some pre-glass framing around the rear a/c unit and fender wells. I also beefed up the area around the ports so when i fasten the face to the box for the final time, i will have lots more to "grab" then just a 3/4" piece of wood in that area.
Ok lets start it out with what i came home to today :D
Posted Image
Posted Image
Posted Image
did my little "dry run" with the baffles on, and i was able to get the sub in there with some "medium effort".
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
just about ready to start glassing...need to make it strong!
What do you think this is for?
Posted Image
Posted Image
If you guessed T-Faketeen K then you are right! Much easier to move around then the amp itself. I had Two choices of mounting for these amps and one of them didnt involve a spot for the batterys. This leaves me with my only option.
Posted Image
Posted Image
One amp right in front of the other staggered. You should be able to see the LED's on the back amp just fine and it actually leaves a NICE spot for the battery bank.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Keep in mind the boxes are ugly and just made to see where it was all going to fall into place. The amps have angles on them and are of course beautiful so it wont be as bad as these pics. This is just to show you whats on my mind or i should say what my only option is :D
here is some pics that Bibby photoshopped to give you guys a better idea how the amps will be.
Posted Image
Posted Image
So now after that, i had to brace this thing up so i can start glassing tomorrow. I was going to do it today but i forgot about bracing and it has to be done first.
Nothin but a few more 2x4's in the mix.....
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
  • Who's Online   0 Members, 0 Anonymous, 3445 Guests (See full list)
