Could be that the gas they are giving you may be watered down, just like they did that to us last year. Made our vehicles run like crap and get horrible fuel mileage. Could be a catylic converted clogging up, clogged air filter. Many things, i would take it to the autoparts store and have them run a scanner on your computer.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Fuel filter needs to be replaces every 50,000miles might want to check that
Try like 15k.
I change mine at 15 and there is a BIG difference in restriction between the old and new. Run your filter to 50k and it will probably be plugged. It's like a <$10 part, why cheap out?
Question, do they change these at oil changes, and where does this filter usually go, towards the engine, or near the gas tank?
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Most of the time it's near the fuel pump.
Kenwood H/U
1/0 wire,
Fuel filter is in the tank. Attached to the pump.
That didnt use to be the case at all, however it is getting to be a more common practice for vehicle manufacturers.
Depending on the year of your vehicle is a big dependent factor as to its location.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
minnesota driver as well. our winter has been damn cold so i would blame it on that and letting your car warmup and such. change your fuel filter and possible new plug wires you will need them eventually so just do it now they dont cost alot of money.
Posted (edited)
Not always.
My car is along the fuel like like 2 ft in front of the tank. I think the 2nd gen W's were like this as well. I'll look it up to be sure.
EDIT: Google search says driver's side frame 'rail' in front of the tank. It mentions needing a special tool to remove the lines, but it looks exactly like my filter, which I did not need tools to remove :shrug:
Edited by white4d96
Too many projects, too little time...
  • Who's Online   0 Members, 0 Anonymous, 637 Guests (See full list)
