Started the fuse holder.
Also the drywall wall screws weren't working so I bought some nice looking screws and tee nuts. Half are in...
Hopefully more tomorrow after work.
Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier
Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
Man you do some really good woodwork, very nice equipment too! Yea those new z140bh's are badass you'll love it. Keep at it man! Oh yea love the car too, bout the only Ford I like.
2009 maxima, currently stock
Thanks bro!
Today I found the wood glue was bonded well so I wrapped it in vinyl. Put some bolts in it. I need to go back and get longer bolts, but you get the idea
And with the fuse
Will work on trimming the vinyl and making the edges tomorrow after the vinyl glue has dried.
that looks great. never would have thought of making something like that
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Trimmed the edges of the vinyl, cut the side pieces, rounded the edges, sanded, sanded with finer paper, a little more sanding, and then sanded just because sanding is fun.
Ended up with this, it's not squared up. Just clamped into place.
Had my first day off today in a long time and I did almost nothing. It felt great.
I did manage to get everything lined up and the sides screwed on. Tomorrow I will "hopefully" get the side pieces wrapped and get the ring terminal holes drilled.
Everything looks very smooth and damn you're gonna love the end result!
wooohoo!
-Acura RL 2005. Blue.
-Stinger Expert Roadkill..Trunk only
-(2) Skar VVX-12's D4 coils
-Dual slot ported to the left custom box tuned @ 32hz
-Audioque 1200D amplifier
A tribe called quest... ftw
Thanks, if turns out anything like it is in my head it will be nice. Hopefully my patience translates into quality....
So tonight I worked on straighting out the carbon, as you can see it gets out of alignment.
Straightened it out with a straight edge
Coated the wood with epoxy to get it ready for the carbon, but the poplar sucked the epoxy up. So I'll have to let this dry, scuff it up and try again tomorrow.
See y'all tomorrow.
