good bass drivers?
mainly to have more control over my amps kinda like meade's kill switch... also don't you need 1 after so many amps?
depends entirely on the hu specs and the amount of amps.... manly the lower ends hus offer theri voltage across all teh terminals combined where as some higher end ones offer that voltage per each output so that itself matters a lot. how many amps are you looking at? aslo before buying a line driver see how much voltage your amps can handle. also im not sure what meade has but i used to have a kill switch on my amp with out a line driver... a kill switch is actually pretty easy just do up a relay that on the off positon it kills the circut so the amp would be "off". i intend to do this on all the amps i install that way i can control waht i hear and when i want to hear it... :^
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
I would strongly recommend the matrix. Run two. use One for front out/rear out to front/rear amps then sub out to a second  matrix then use the three outs to your sub amps. If your amps have line outs just use that. Go to the matrix site look up the manual they have the exact setup I'm talking about diagrammed
  • 4 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 861 Guests (See full list)
