I have a Rockford Fosgate T2 12" and I built a box by Rockford specs and it doesn't hit nearly as hard or clean as i thought it should, I want to go with a bigger box but i don't know if that will fix it and I don't even know how big I should go or the ports. The amp i am using is a Rockford Fosgate T5002 and it is turned up 3/4 way. It's in a 2002 Chevrolet Tahoe so i got plenty of room.Let me know if you can help,thanks.
Here is the link to the box I built.
http://www.rockfordfosgate.com/products/product_details.asp?item_id=91849&locale=en_US
I design this box for you real quick, let me know if you like it.
Box Dimensions
Height - 14"
width - 30"
Depth - 18"
Port Dimensions
Height - 12.5"
width - 3"
length - 22"
Box Stats
cu.ft after displacement 2.62 @ 36.75Hz
Add some bracing and that will bring you to 2.5cu.ft @ 37hz
Cut Sheet List
Top - 30"x18"
bottom - 30"x18"
sides - 12.5"x16.5"
Back - 30"x12.5"
2-18" Fi Btls
2-RF T2500-1bd
box 14cu.ft after displacement tuned @ 32hz.
Socal Box Designer/builder
Box Dimensions
Height - 14"
width - 30"
Depth - 18"
Port Dimensions
Height - 12.5"
width - 3"
length - 22"
Box Stats
Cut Sheet List
Top - 30"x18"
bottom - 30"x18"
sides - 12.5"x16.5"
Back - 30"x12.5"
I will try to make that box this weekend if i feel better,i appreciate the help though man thanks
Posted (edited)
What exactly do you feel is lacking with your current box? Is it overall output, or just output in a certain region that is disappointing you?
Hey, you're local! :D
Edited by RAM_Designs
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
It's just not hitting right to me,it's got a good amount of watts going to it but just doesn't sound right. Maybe if you're ok with it I could meet up with you and you can listen to it and give me your personal opinion. I've also got a Power Bastards 250 amp alternator on its way to my house this week maybe this will help.
