RabidNinjaSquirl Posted March 7, 2011 Report Share Posted March 7, 2011 I have a Rockford Fosgate T2 12" and I built a box by Rockford specs and it doesn't hit nearly as hard or clean as i thought it should, I want to go with a bigger box but i don't know if that will fix it and I don't even know how big I should go or the ports. The amp i am using is a Rockford Fosgate T5002 and it is turned up 3/4 way. It's in a 2002 Chevrolet Tahoe so i got plenty of room.Let me know if you can help,thanks. Here is the link to the box I built. http://www.rockfordfosgate.com/products/product_details.asp?item_id=91849&locale=en_US Quote Link to comment Share on other sites More sharing options...
chevyhoe08 Posted March 8, 2011 Report Share Posted March 8, 2011 are you putting the box behind 3rd row seats or behind 2nd row seats.? Quote 2-18" Fi Btls 2-RF T2500-1bd box 14cu.ft after displacement tuned @ 32hz. Socal Box Designer/builder Link to comment Share on other sites More sharing options...
RabidNinjaSquirl Posted March 9, 2011 Author Report Share Posted March 9, 2011 are you putting the box behind 3rd row seats or behind 2nd row seats.? I'm putting it behind my 2nd row seats,I took out my 3rd row. Quote Link to comment Share on other sites More sharing options...
chevyhoe08 Posted March 9, 2011 Report Share Posted March 9, 2011 I design this box for you real quick, let me know if you like it. Box Dimensions Height - 14" width - 30" Depth - 18" Port Dimensions Height - 12.5" width - 3" length - 22" Box Stats cu.ft after displacement 2.62 @ 36.75Hz Add some bracing and that will bring you to 2.5cu.ft @ 37hz Cut Sheet List Top - 30"x18" bottom - 30"x18" sides - 12.5"x16.5" Back - 30"x12.5" Quote 2-18" Fi Btls 2-RF T2500-1bd box 14cu.ft after displacement tuned @ 32hz. Socal Box Designer/builder Link to comment Share on other sites More sharing options...
RabidNinjaSquirl Posted March 9, 2011 Author Report Share Posted March 9, 2011 I design this box for you real quick, let me know if you like it. Box Dimensions Height - 14" width - 30" Depth - 18" Port Dimensions Height - 12.5" width - 3" length - 22" Box Stats cu.ft after displacement 2.62 @ 36.75Hz Add some bracing and that will bring you to 2.5cu.ft @ 37hz Cut Sheet List Top - 30"x18" bottom - 30"x18" sides - 12.5"x16.5" Back - 30"x12.5" I will try to make that box this weekend if i feel better,i appreciate the help though man thanks Quote Link to comment Share on other sites More sharing options...
RAM_Designs Posted March 11, 2011 Report Share Posted March 11, 2011 (edited) What exactly do you feel is lacking with your current box? Is it overall output, or just output in a certain region that is disappointing you? Hey, you're local! Edited March 11, 2011 by RAM_Designs Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
RabidNinjaSquirl Posted March 11, 2011 Author Report Share Posted March 11, 2011 What exactly do you feel is lacking with your current box? Is it overall output, or just output in a certain region that is disappointing you? Hey, you're local! It's just not hitting right to me,it's got a good amount of watts going to it but just doesn't sound right. Maybe if you're ok with it I could meet up with you and you can listen to it and give me your personal opinion. I've also got a Power Bastards 250 amp alternator on its way to my house this week maybe this will help. Quote Link to comment Share on other sites More sharing options...
