DC Sound Lab
So i ordered a DC level 5 18inch sub ill be running a lanzar 6000d amp in a cobalt ss, can anyone give me ideas for a custom box and the best way to wire this sub?
Specs of the amp
1 x 3000 Watts RMS @ 4 OHMS
1 x 4000 Watts RMS @ 2 OHMS
1 x 6000 Watts RMS @ 1 OHM
Mono Block Subwoofer BIG POWER Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB
Gold plated RCA Inputs
Gold plated Line outs
Custom Terminal Block for Speaker Connections
Thermal,Overload Short Protection
Variable Low pass Filter (50Hz~150Hz,24dB/Octave)
Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Remote Bass Control
Input Impedance:10K Ohms
Soft Turn On/Off
THD: 0.1%.
S/N Ratio: 90B
Input Sensitivity: 200mv~4V
Freq. Response: 20Hz~250Hz
Dimensions :10.08'' (W) x 2.12'' (H) x 27.6'' (L)
Edited by darksoul187
2009 Malibu LTZHead Unit - Pioneer AVH-P4300DVDSubs - 2 DC Audio m2 XL 15'sAmplifier - DC 5kWire - KnukonceptzAlternator - OhioGenBatteries - 2 XS Power 3100's, 1 d4700
You want to run 6k to that sub? I did and it's difficult... What is your electrical like? Coming from the fact that you don't know how to design a box nor wire up the sub, what gives me a reason to say that youre still not running stock alt and factory wiring?
2006 Nissan Z Track.
My Feedback Thread
i used to think a band pass was something you were around your neck or something.
i have 2 batterys with three grounds 0g wireing also battery is mounted stock inside cobalt trunks wire is redone with 0g also 4volt headunit and before this is all said and done ill have my big three done along with a upgraded alt that im working a deal on as we speak. boxes just aint my thing. as for wireing the sub i just dont want nothing bad happening its a 1ohm sub btw
5.5ft3 after displacements with 17-19 in2 port per ft3. Make sure you scope the amp to be sure you are getting clean power.
great thank you
no. I would use around 4 cubes since you're almost throwing triple the power to it. I had one strapped on 2 saz3000's and still had some problems with it in a 3.5 cube box.
My Feedback Thread
What VC configuration? you sub 1om sub ? Is it a d1? and id say 5cf after displacment with 16-18 sq in of port tuned to 35
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
its a D1 lvl5 18"
  • Who's Online   0 Members, 0 Anonymous, 968 Guests (See full list)
