Okay, so I got this baby in today, and it works like a charm! Instal was easier than I expected, and overall I am really happy with my purchase!
Here are some pics of the install!
Fist thing was get stuff out of my way!
So I could get to this
But as you can see, the wire I needed was kinda tricky to find, since there were 7 or 8 of them the exact same color!
So I decided to try the to get it right before it went into the PCM
Found it! ;)
So now some tape and care when putting it on!
And that part is pretty much done, other than a few zip ties!
So now on to a mounting location. Hmm, this looks good to me!
All cleaned up and mounted!
And how bout a jumper ground? I think so!
And there she is, fully installed!
And here is a little video I made when I first started the car after the install. Hear the frar in my voice when at first I forget to turn the HU on, which powers my volt meters!
And yeah I know, I'm a dork! That's why I hate talking in videos!
:postwhore:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
Alright, I finally started on the box for the 3 12's. I have had all three for a while now, but only run two cause I'm trying to let the other one catch up now and equal them all out, before they go in the same box on the same power. It's a simple design that I am doing completely on my own, from design to construction. Subs up port back 7.5ft^3 @33hz FTW!
Here are some pics. I hope to get it completed tomorrow and ready for paint. Going w/ the same as dash (midnight black metallic)
El port
Port(left) and top/baffle(rt)
More tomorrow long as I get no setbacks! Thanks for lookin' :drinks:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Got a little more done today. Hope to get more tomorrow!
Got the port
Completely assembled, no glue.
I then took it apart and started the finally assembly. All screws were pre drilled and counter sunk. All joints glued w/Tightbond ftw!
I'll fg resin the whole inside tomorrow and cut baffle and hopefully finish assembly! Then, long as it sounds good, I'll make it pretty :clapping:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Well I got a little more done.
Got the baffle cut
And the dowel rods cut and attached to the baffle
And most of the bracing
Test fit... looks good!
Now for some Kitty Hair
Glued and ready!
Baffle glued and more Kitty Hair added! Also bracing for the baffle
And that's where I stopped for the day. Let the glue and Kitty Hair dry, and tomorrow I'll smooth it all out, finish assembly and get it all resined up inside!
In case you haven't noticed, I'm taking my time :peepwall:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Well, I got a little more done today.
Got some body filler - NOT BONDO
Then started with some sanding and test fitting...
Then I started rounding some corners - port inside
Now time to break out the dremmel and put in more bracing
I notched it out so I could "marry" the braces
Side to side is in there!
And don't forget the front to back!
Glued and screwed!
She's gettin sexy!
Now for some filler
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
And now for more sanding!
Blow it all out a lil...
More filler around the port opening
Then after getting it baby-butt smooth, time to finish the last of the bracing.
This is where she sets now, tomorrow she gets resin first thing!
Slowly but surely...
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
  • Who's Online   0 Members, 0 Anonymous, 787 Guests (See full list)
