I was wondering if it was possible to wire a 12" Alpine type x to 1ohm? I have been looking around and couldn't find anything about it.
only if it is a dual 2ohm voice coil....what do you have, dual 2ohm, or dual 4ohm?
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
On their site if you look under the other subs it says
"SWR-1023D
10" Subwoofer (2Ω + 2Ω) <-- the thing in parenthesis
Price: $179.95"
If they make a dual 2ohm [2 voice coils each one is rated at 2 ohms] or if you buy (2) dual 4ohm voice coils [2 Voice coils each one is rated at 4ohms.]
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
They are dual 4ohm.
They are dual 4ohm.
then you can only wire a single sub to 2 ohms:( but you can wire 2 of those subs to 1 ohm:)
7" BDS HC lift kit
They are dual 4ohm.
Great because i have 2 of them. Where do I put the clips on the subs because there are 3 differnt spots and also what holes do i put the wires in? Thanks
put the clips in the 2 outside spots, so the middle one should be empty and it will take it down to a 2 ohm load, then wire + to + and - to - and it will take you down to a 1 ohm load
Car: 1995 Thunderbird
System:
Pioneer deh5100ub HU
Pioneer/Lightning Audio 5x7's
1 Hifonics 1610D amp
2 Obsidian Audio 12's
4cu.ft. box tuned to 30hz
8 farad Boss Audio cap
4 gauge power/ground wire
Youtube
Facebook
  • Who's Online   0 Members, 0 Anonymous, 705 Guests (See full list)
