i soon will have 2 hifonics amps.
1 bass amp with a 140 amp fuse on it
and 1 4 channel amp 4 my mids and highs with a 60 amp fuse on it.
would it be better to go with a 250 amp anl fuse or a 200 amp anl fuse or 1 anl fuse per amp?
incriminator audio death penalty 18' dual 1.6 to be exact.
hifonics brz2400.1 wired 2 .8 ohms.
hifonics hfi 100.4 mids and highs.
hifonics zeus 6.5 separates 11mm tweets.
3 300 amp fuses, 0 gauge wire.
yellow top optima in front and back.
alpine head unit.
I would use a 250 amp fuse. I like to have a little headroom in my fusing exspecially if my amps have built in fuses.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I like separate fuses.
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
only tha bass amp has a built in fuse but tha 4 channel amp dont.
alpine head unit.
you are talking about the main fuse up front by the battery aren't you?
yea if i should get a 200, 250, or separate fuses.
alpine head unit.
Then you will need to add another fuse right before the 4 channel and for that fuse I always stick to the manufacture's recommendation.
I don't see any reason to use dual ANL fuses up front by the battery unless you have more than one wire up there or the combined value of the fuse excead's the anything you can find.
Edited by ISO
the 4 channel amp has 2 30 amp fuses on the outside and the bass amp has 140 amp fuse on the inside, so y do i need a fuse be4 tha 4channel amp?
alpine head unit.
because you said this.
Edited by ISO
  • Who's Online   0 Members, 0 Anonymous, 1873 Guests (See full list)
