I just got a 05 civic with the 6 disc cd changer and i would like to keep it for now. The problem is i need a remote turn on lead for the amp and i don't want to splice the accessory wires. Are there any adapters i could use in the fuse box for the accessory fuse that will have a way to run another wire to the amp?
Yes,if you have small blade fusses there is a device that wil slip over one end of the fuse and allow you to use a female connecter for your wire.Most install shops have something like that..if not electrical warehouses will...good luck.....T-taps are another way to go..
Edited by dr.db
Well I looked for a fuse tap and all i could find is the larger ones so they will not work. I got some inline fuse taps but i cannot find an acc. wire. Does anyone know were a acc. wire is on a 2005 civic 2dr.?
The wiring on a 05 civic is all tied up in the dash and hard to get to. I just got the car and my dad doesn't want me to take any panels off. But i got the problem solved i found a wire.
  • Who's Online   0 Members, 0 Anonymous, 958 Guests (See full list)
