I just got a 05 civic with the 6 disc cd changer and i would like to keep it for now. The problem is i need a remote turn on lead for the amp and i don't want to splice the accessory wires. Are there any adapters i could use in the fuse box for the accessory fuse that will have a way to run another wire to the amp?
Yes,if you have small blade fusses there is a device that wil slip over one end of the fuse and allow you to use a female connecter for your wire.Most install shops have something like that..if not electrical warehouses will...good luck.....T-taps are another way to go..
Edited by dr.db
  • Who's Online   1 Member, 0 Anonymous, 686 Guests (See full list)
