Alright, Steve (BassikInstincts) drove out today to get measurements, help get the birch to the shop, and the aeros squared away. This will be for his 15" Crossfire XS V2 on a SAZ4500 in his Malibu. The whole enclosure will be double-layered and finished off with a radius on all of the exterior corners (minus the bottom).
Specs come to:
-3.65 cubes net
-36.5Hz tuning
-(3) 4" aero ports
Got started and all of the vertical/side panels doubled-up but no pics of that for right now
Alright, got started on these ports a little while ago...not exactly the simplest of tasks to do perfectly but they're coming along (had to make them very tightly packed to fit the sub next to them...you'll see)
The planning took a little while but got it done...
First aero's outer flare cut...
2nd aero outer flare cut...
Got rid of the excess material around the inner ring on the inside flares...
Inside flares...and a warsteiner to help the building along today.
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Random pic of the interior flares...
Team Tupperware
Finally done :):D
Perfect fit for the D3100's next to it :);)...(the box next to it is the exact size of a D3100...can't really tell, but there's like 1/16" of clearance, perfect).
Schwing!
Team Tupperware
you are amazing at what you do
R.I.P!
(Nov-29-2009)
92 explorer
current build
Thanks, guys :);):D
Team Tupperware
  • Who's Online   1 Member, 0 Anonymous, 1405 Guests (See full list)
