Different ohms on different channels is fine but having mixed ohm loads on a single channel isnt really a good idea.
Example from above of 3 tweeters parallel seriesed to 2 tweeters in parallel would work but would likely cause some strange power issues resulting in different harmonics being produced from each set of drivers on the channel. In short it would just sound strange.
If you had a single 8 ohm driver and a single 4 ohm driver in parallel it would be fine,
Edited by STEvil
Hammerdown... 1%
Alright cool, didn't know that..So yeah, ignore my post above. But how would a single 8 ohm with a single 4 ohm be any different?
They would likely be different drivers meant for different purposes - say a mid and a tweeter. Should have specified that before, my bad ; )
Edited by STEvil
Hammerdown... 1%
