That's 2k of unclipped signal. Running 2,000wrms daily requires some electrical upgrading to keep your voltage around a steady 14-14.4. Dropping below this may result in some clipping. It'll take 2k, but if it is a clipped musical signal, it won't be taking that 2k for too long.
You have to be very careful when running more than the subwoofers rated rms value. You can gain quite a bit of performance if you know what you are doing in running more power, but also very risky if you don't. The manufacturer can typically tell why your subwoofer blew. If it was indeed from sending the driver a dirty signal or too much power, they will not cover that under warranty. Just an fyi. :peepwall:
So just by you asking this question leads me to believe that you should make sure you do a little more reading up before you plan to just throw that kind of power on that sub.
Best of luck to ya. :drinks:
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
True that. I hate to see someone buy a quality sub/amp or anything for that matter.. and not know how to use it properly.
2 18's Wall Build Under Construction
My YouTube
2000 Mercury Cougar Build Log
^yeah I know lol was just wondering how much I could get out of one if I do it right.. Got a pair of re SX 15's now and wanted to make sure that it will handle the power I'm feeding them..
