dirtboi22 Posted March 24, 2011 Report Share Posted March 24, 2011 ok quick question I know you guys will be able to answer.. Audioque HDC3 15 with copper coils can handle what daily? rms? Quote Link to comment Share on other sites More sharing options...
techforce Posted March 24, 2011 Report Share Posted March 24, 2011 I have a pair of the copper coil 15's on an AQ3500, so they are seeing 2k each daily and dont even get warm Quote Link to comment Share on other sites More sharing options...
dirtboi22 Posted March 24, 2011 Author Report Share Posted March 24, 2011 2K sweet!! thanks man! Quote Link to comment Share on other sites More sharing options...
dirtboi22 Posted March 24, 2011 Author Report Share Posted March 24, 2011 What about aluminum coil? Quote Link to comment Share on other sites More sharing options...
Cashdollar2009 Posted March 24, 2011 Report Share Posted March 24, 2011 That's 2k of unclipped signal. Running 2,000wrms daily requires some electrical upgrading to keep your voltage around a steady 14-14.4. Dropping below this may result in some clipping. It'll take 2k, but if it is a clipped musical signal, it won't be taking that 2k for too long. You have to be very careful when running more than the subwoofers rated rms value. You can gain quite a bit of performance if you know what you are doing in running more power, but also very risky if you don't. The manufacturer can typically tell why your subwoofer blew. If it was indeed from sending the driver a dirty signal or too much power, they will not cover that under warranty. Just an fyi. So just by you asking this question leads me to believe that you should make sure you do a little more reading up before you plan to just throw that kind of power on that sub. Best of luck to ya. Quote On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not. Link to comment Share on other sites More sharing options...
nickfs442 Posted March 24, 2011 Report Share Posted March 24, 2011 That's 2k of unclipped signal. Running 2,000wrms daily requires some electrical upgrading to keep your voltage around a steady 14-14.4. Dropping below this may result in some clipping. It'll take 2k, but if it is a clipped musical signal, it won't be taking that 2k for too long. You have to be very careful when running more than the subwoofers rated rms value. You can gain quite a bit of performance if you know what you are doing in running more power, but also very risky if you don't. The manufacturer can typically tell why your subwoofer blew. If it was indeed from sending the driver a dirty signal or too much power, they will not cover that under warranty. Just an fyi. So just by you asking this question leads me to believe that you should make sure you do a little more reading up before you plan to just throw that kind of power on that sub. Best of luck to ya. True that. I hate to see someone buy a quality sub/amp or anything for that matter.. and not know how to use it properly. Quote 2 18's Wall Build Under Construction My YouTube 2000 Mercury Cougar Build Log Link to comment Share on other sites More sharing options...
dirtboi22 Posted March 24, 2011 Author Report Share Posted March 24, 2011 ^yeah I know lol was just wondering how much I could get out of one if I do it right.. Got a pair of re SX 15's now and wanted to make sure that it will handle the power I'm feeding them.. Quote Link to comment Share on other sites More sharing options...
