2x 15" ported box !
Vannos
hi all
my name is robin 19 years old and I live in Netherlands
I now observe a common question but my english is not so good
So post it here on this topic
I had first 2x 12 inch subwoofers in a sealed coffin.
but now want something else 2x 15 inch in a ported box
I have a number of specifications of the woofer at least the liter
75 liters per woofer so totally 150/155
hand, the manufacturer per woofer this> suggestion Bass Reflex Cabinet, 75 Litre / 1 Reflexrohr / port
Ø 10 cm, Length / legth 25 c
and I think they want that I make a round port, but I do not want nice. I want square or rectangular port
but my question is how big should the square or rectangle.
I have the wood already cut to length but not cut the holes for the woofer and port.
22mm MDF material
Here an over view of the box for the woofers are top of the box
but do not know how to place the gate.
the gate sits here in the upper side
of can i make te gate in the front of the coffin
I hope you can help me, because it wants to do well at a time, hence my question on this forum (come via youtube)
(my english may be a bit confusing)
Gr, robin / vannos
:trippy:
Let's see if I can't help you try and explain what you want better.
What subwoofers are you going with?
What are the dimensions you want to stay within? (Hight x Length x Width)
We will start with that.
:drinks:
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
You used a coffin for a sub box??? LOL what do you drive? A hearse?
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
i mean a sealed box - that google translator is crazzy :P
(Hight 34cm x Length 86cm x Width 90cm)
i have now a sealed box but he is not finishd now, i am waiting for the woofers
the company that delivers the woofers gives a delivery time of + - 1 week
here a picture of de sealed box
Just to make it a little easier for others to understand.
Box Dimensions: (Hight 13.4" x Length 33.9" x Width 35.4")
I going to say you want it for daily so, tuned to low/mid 30s... so 34 hertz or so?
Do you know the name/brand of the subs?
Youtube Channel
Mac audio stx 15
Prinzip / DIN-Ø 380 mm
Principle / DIN-Ø 15”
Belastbarkeit RMS/max. 600 / 1200 Watt
Power handling RMS/max. 600 / 1200 watts
Impedanz 4 Ohm
Impedance 4 ohms
Frequenzbereich 18 - 500 Hz
Frequency response 18 - 500 Hz
Schalldruck 93 dB
Sound pressure level 93 dB
Außendurchmesser 380 mm
Outer diameter 380 mm
Lochausschnitt 357 mm
Cutting out 357 mm
Einbautiefe 170 mm
Installation depth 170 mm
Fs 22 Hz
Qes 0,27
Qms 5,17
Qts 0,26
Vas 335 L
Xmax 24 mm
Rdc 3,3 Ohm(s)
Korb Material Stahl/black chrome
Basket material steel/black chrome
Membran-Material mehrlagig gepresste, luftgetrocknete Papiermembran
Cone material Multi-layer pressed and air-dried paper cone
Gehäuse-Vorschläge Geschlossenes/closed, 38 Liter
Cabinet suggestion Bassreflex, 75 Liter / 1 Reflexrohr/port
Ø 10 cm, Länge/legth 25 c
Ok from what i understand, according to the company (Their site) they want a box 2.65 cubic feet per woofer (5.30 total) with recommended port of 4" wide by 10" long which would give you a tuning of 22.22 hertz.
After messing with the box calculator I came up with (using the recommended size box the company states of 5.30 cubic inches) 6" high x 6" wide x 10" long which gives you a tuning of 35 hertz.
Using the dimensions you gave me. The box would be 7.17 Cubic feet (203 litters).
I would use a port 7" High x 7" wide x 10" long (17.8 cm x 17.8 cm x 25.4 cm). This would give you a port area of 6.83 square inches per cubic foot.
Another option would be to make a port 9" x 9" x 20" (22.9 cm x 22.9 cm x 50.8 cm) which would give you a port area of 12.8 square inches per cubic foot.
I hope I wasn't to confusing, if you need more help just ask.
I know there are members on here that are better at this them me but, this is what I have cam up with. I any one else can add on or confirm this to be correct would be great.
Youtube Channel
oke thanks for calculating
hier a picture of de box
my last question is whichis the best from this list
to make normal use for
From what I've read on the forums, people have said to usually go with the bigger port. So, I'm going to say the second option of 9" x 9" x 20" (22.9 cm x 22.9 cm x 50.8 cm).
Good luck! :drinks:
Youtube Channel
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
