lgnmgr Posted March 25, 2011 Report Posted March 25, 2011 i ripped out all the plastic and stuff now all i have is a bare trunk but it seems to have a slight leak or condensation issue. im definitely going to be using sound deadening mats for the whole thing but i was wondering if that will be enough and if it would be a good idea to seal the trunk prior to putting the mats down?
keepinitloud Posted March 25, 2011 Report Posted March 25, 2011 so you just took out the plastic trim around the trunk opening? shouldn't be leaking unless you have a leak in your trunk or rear window seal and you should lay down the sound deadner before box installation and sealing off 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
T_Clark Posted March 25, 2011 Report Posted March 25, 2011 If u have a sunroof it's the front draing tubes they need to be cleaned out(they run down the a frames) I had the same problem with mine.
slim2fattycake Posted March 25, 2011 Report Posted March 25, 2011 yeah, check the tubes on the sides of the back of the trunk. They should be running out of the side of the car close to the bottom of the rear quarters. SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
lgnmgr Posted March 25, 2011 Author Report Posted March 25, 2011 No sun roof. seems to be a build up of condensation. it's really confusing cuz i dont actually see the moisture coming from a particular spot. would the sound damping material be enough to seal the trunk?
Duaber Posted April 25, 2011 Report Posted April 25, 2011 Honda have been known to leak from the tail lights. Best test to do would be having another person there spraying a hose over the trunk while you sit in the trunk to find where the leak is coming from. Team Sundown Team XS Power System: Car: 1997 Honda Accord Head unit: Alpine CDE-7870 Amp: 2 Sundown saz-1500 Battery: kinetik 1400 and 2400 Subs: 2 Audioque HD310 D2
