Big 3 upgrade help
Forget the fuse box, just leave it as is. ADD a + wire from alt to battery, upgrade your engine block to frame and battery tonframe grounds.
Edit: you can upgrade it if you want, but it has nothing to do with the charging system once you do the big 3.
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
You will still need to use an inline fuse holder on the wire that runs from the alt positive to the battery positive. Like others have said you dont need to up grade the wire that runs to the fuse box, but you can if you want to.
Car: 2000 Ford Focus 4 door
HU: Kenwood KDC-X395
Front Highs: stock
Back Mids: Stock
Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz)
Amp:Audiopipe APSM 1500 mini
Wiring: KnuKoncepts Kolossus 4awg
you can just use an inline fuse from alt to battery +, no need for fuse box upgrade.
-2002 Impala Ls
-Optima yellow top x 2, big 3
-Pioneer 5.8" touchscreen
-Infinity 6.1 Kappa Perfect Components
-Alpine type r 6" coaxial x 4
- Audio Que hdc312 x 2
-Mb quart 4 ch. x 2
-knu wire
-Audio Que 2200w amp
- db electric 220amp alt
  • Who's Online   1 Member, 0 Anonymous, 1167 Guests (See full list)
