Hey guys you know about my 4 tens that I just installed I have the right side subs wired together into 2 ohm load and then the left side subs the same way into a 2 ohm load,. then on my two channel amp which in turn would knock it down to 1 ohm. So I guess I need a amp to do this will for a good price.
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Bump this up guys yall got any suggestions for a good amp to give my subs 200 watts rms a piece and I have 4 subs. The highest I will spend is 150 unless you guys have a amp yall wanna sell for a good price. I have two subs wired to gether so thats two ohms then the other two subs the same way, then on a two channel amp what do you think I could get without having to change my wiring up?
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Have you tried Craigslist.com? Don't ever but pyle for ANY reason. I'd bet you that amp doesn't even put out 400 RMS & dirty power at that. 800rms for $150? Should be able to find something somewhere.
On the other hand, I've personally owned the AP2000 from profile, & it truly does do it's RMS of 900+watts & bangs hard. I actually would recommend it.
Edited by Chris
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
When I get home ill draw how I have the subs wired and you can tell me if it will work on that amp
To big and I don't like plye
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Got a link to that amp?
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Here's one, about the cheapest I found it for.
http://www.millionbuy.com/prfap2000.html
The amp is 2 feet long & has 4 25amp fuses so it's fairly beefy.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Looks a little to big wait until about 4:00 my time and its 11:43 now and ill draw how I have my subs wired and if I get a amp I don't want to change the wiring!!
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
