welcome to the forum man! even though you have 2 posts already haha. but yes ideally you would need an amplifier if you were to add a subwoofer(s) to your car. to start off, what kind of subwoofers were you planning on using? model numbers would help greatly here. do you have a box for said subwoofers already? how much are you willing to spend on an amp? do you have an aftermarket headunit installed? do you have all the wires needed to install an amp? if you could answer these questions to the best of your ability, that would help GREATLY.
Hey guys,
I'm looking to get 1 - 2 subs put in my car but was wondering. Do I also need an amplifier and if so do I need a certain type of amplifier?
yes you will need an amplifier unless you buy a powered set up. a powered set up will usually be like a regular sub and box setup , but it will say powered meaning it has an internal built in amp. and all you will have to do is run a power,ground,remote and rca's to it.
if your set up isn't powered you will need an external amp. as for the type of amp you will need it depends on the subs. if you were running 1 sub you would need a monoblock, or you could bridge a two channel amp. for 2 subs you could get 2 mono blocks or wire the subs in parallel to one amp.
but it all depends on how much power you need, how many ohms. and how many ohms your amp can do safely. some amps are only 2 ohm stable where other amps can be dropped to .5 ohms.
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
650WRMS each.....if you were going to do a 2 sub setup then i would find a monoblock amp that has an output of about 1200WRMS at a 2ohm load. to get the 2ohm load you will have to wire your subs in parallel
hope that helps :)
Honda Accord SirT + Mad sounds = Awesomeness
VTEC go BRAAAAAPPPP :P
http://www.stevemeadedesigns.com/board/topic/141261-99-accord-sirt-sq-build/
Alright well i never done the big 3 so i see in my vision my truck on fire...
if your looking to match the vibe subs with a vibe amp i whould get a black box bass 5 it will do 1500rms at 2ohms and from what i have heard is they are under rated so it will do more then 1500rms at 2ohms which is when they push there peak power
1998 neon R.I.P 137.5 db's
Youtube videos http://www.youtube.c...tingarrett64067
2000 Eclipse
Headunit = pioneer avh-p1400dvd
Subwoofers = 2 DC audio lvl 2 12's
Amp= Vibe bass 5 1500rms @ 2ohms
​Single run of 0awg power and ground wire
( Big 3 wire upgrade comeing soon )
  • Who's Online   0 Members, 0 Anonymous, 536 Guests (See full list)
