Recently I put MSD Igntion on my car (SCI Ignition box, external coil, new plug wires, distributor cap, and rotary button) and of course picked up engine noise as well... Does anyone know a way to solve this problem? Or make it not as bad? A lot of it may be from my Pioneer radio, which had noise before the ignition was installed, but it got worse after it was. Ill try another radio to see if it helps any.
1999 Civic Si
Current setup - 147.5 db
Memphis Mojo 12
Memphis Mojo 2500
check all your grounding points, especially for the new ignition, make sure you ground to bare metal.
Thanks, but already done that. All the RCAs have been grounded, amps are grounded great, and so is the ignition.
1999 Civic Si
Memphis Mojo 12
Memphis Mojo 2500
Forgot to mention, its not like normal engine noise, the constant whistle, its more like a ticking.
1999 Civic Si
Memphis Mojo 12
Memphis Mojo 2500
try using better rca's
2007 Pontiac G6 on 20's
Current System-
Jensen VM-9312 in-dash
(1) Kicker 1500.1
(2) DD 1500 Series 12's
Running Knu Koncepts 1/0 wiring
145.6db- Floorboard
162.9db- Port
1983 Toyota Corolla Station Wagon (SPL Vehicle)
(Under Reconstruction)
