i need some help on this one
it will be for a 15" AP/SPL
a 40hz (the subs F/S) wave = (rounds to) 7' x 4
so my port length should be 7'
its a 15" sub, so i will need it to be 170"^2
im i correct?
heres the design (its not to scale yet, i want to make sure im right before i sketch it up)
any help would be appreciated
thats really him? you cant be serious. i knew there was something wrong with that kid. he's like the rap version of an emo kid.
Dylan Dude = PWN3D on 2 different forums in one night
your 5.75 isn't the right measurement. by the .75, im guessing your usin 3/4 mdf.......soooooooooo..............it would be 10.75 because half of the top line is 5" in itself
Check out my builds......I just built a badass t-line
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
i dont follow what your saying
it you can modiy my design, it would probably help a little :blush:
I can't figure out how to mod that pic but
Instead of the inside length measurements: 39.125", 39.125", 5.75"
Make them 36.625", 36.625", 10.75" ;)
Now that will be $20 :D
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
thanks :lol:
and ill get that $20 to you by the 2nd tuesday of next week :P
don't change the shape any......just the inside measurements, those are the correct ones to equal 7 feet
haaaaaaaaaaaaaaaaaaa I just now got the SECOND tuesday part........."your a quick one" :lol::D:lol:
Edited by JustinT
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
thanks for all your help man
ill try to get the sketch up by tomorow
and ill make a work log as soon as i get money
BTW: im making to of these ;)
2 AP/SPL 15s + T-Line + as much power as they can take = ??? we'll find out i guess :lol:
AP SPL? Iam not familiar with that.
Not all subs will sound good in a T-line. If its a dedicated SPL sub, Iam assuming the Qts to be high, if it is, your sub will play loudest with a more narrow bandwidth. 1 thing you can do to help with the sound is to line the tline with 1" of poly fill . It will help a little bit. Also, tapering the line would help some too. Basically start off with a narrow line, and slowly open to a larger mouth, that will allow the sub to play louder. If it is a higher Qts sub, you may want to taper the line backwards, start off large, and slowly close the line opening towards the end.
Higher QTS will sound better with rock, techno, fast beat bass
Lower qts will give you a better low end concentrated, gentle roll off sound wich would be great with rap, jazz, other low end bass tracks
specs:
ATOMIC APOCALYPSE SPL
UNITS AP150D2
Revc (ohms ) 1.00
Fo (Hz) 40.19
Sd (sqM) 0.089
Bl 13.87
SPLo (dB) 93.51
Xmax (mm) 10
Dvc (mm) 62.50
Qms (m.q.) 3.74
Qes (e.q.) .320
Qts (totQ) .296
Vas (liter) 72
Cms (uM-N) 64
Mms (gram) 229
and the 10mm x-max is bullshit
they have MUCH more than that
Edited by Cap'N'Crunch
