So i am interested in building my first ported box.
I have experience building many sealed boxes, but never got up into building ported.
I only have two questions...
How do you determine how big the box needs to be?
Say you have a sub that need between 4cf and 8cf for a ported box...
So ill choose a nice middle number of 6cf for my box.
Does this 6cf include the port? or does the port take away from it, so i would need to build a box that is like 6.2cf and then put the port walls in? Also, if the 6cf DOES NOT include port, how do you calculate the volume in cf of the box with the port in there, since of course it would have an open vent....
This will be my first ported box, and I wanna do it right...
Oh and I almost forgot, would Brad Nails from a Nail Gun be good for a ported box or screws? what kind of double sealant would be good. I usually use three forms of bond, wood glue between the MDF sides, liquid nail on the inside edges of the box, and most of the time I use a nail gun for some extra support.
What do you guys think? :noob:
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
you look at the specs of the sub. it should say an amount of airspace for ported and an amount for sealed. as for the amount i think it has to deal with the tuning as well as the port but dont hold me to that.. some subs will even tell you what size round ports to use
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Same way I did, use the box spec program. I didnt know what I was doing either 2 days ago. Looked around, got a little input, used the program and built most of a box today for a solo 15. 4ft^3 tuned to 33hrtz. Do a little research and you will find its not to hard :good:
Since were all having a moment of truth.
I hate country too..
I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick.
it's determined by the size of the sub. Generally 10's need about 1 cubic ft AFTER ports, 12's need 2 cubes, 15's need 3.5 cubes, and 18's need 6. That's just general and don't go by those.. All depends on the sub what what other recommend.
Yes it includes the port. When a spec sheet says it needs 2 cubes, that means 2 cubes after the ports in there.
Theoretically glue will hold the whole box together since the glue actually bonds the pieces together. Just glue, and use like 1.5" nails in the nail gun and go down the sides about every 3 or 4 inches and you'll be good. No need to seal the inside with silicone.
2006 Nissan Z Track.
My Feedback Thread
Wut box spec program? LOL...
XS D6500 $245.65
there is the torres one on here or rockford has a way dumbed down version
Yeah I was thinking about getting two FI BTL 15"s which require Ported box: 2.5-5.0cuft
I figured id build a box 4cf tuned to around 34hz
I just got confused as I know the port for a slot port would probably only be a small little L but of course filling the box with would would take out some cf although not much, just a tad, do you just subtract the cf size of the port woof minus the outer dimensions of the box? For example. I have a box that is 4cf measuring the outside dimensions. I put in lets say .5cf of MDF to build the L for the port. Does that mean my box would be 3.5cf tuned to 34 hz? i know thats kinda confusing. LOL hopefully you'll get it.
I appreciate it guys! This sites really great for all car audio!
XS D6500 $245.65
torres wasnt supper hard and I suck at math lmao
HMMM. I have been looking through all the help files and doing searches... I cant find it at all. Could you possibly provide a link :D thank You!
XS D6500 $245.65
  • Who's Online   0 Members, 0 Anonymous, 583 Guests (See full list)
