Viper 5902, would this be all i need?
I'm going to be moving into an apartment complex, and i do not want people fucking with my car... So i am trying to minimize the risk as much as possible.
Would all of these components work together?
Viper 5902
http://www.amazon.co...=A2LYDS8AIU9VMR
Audio sensor
http://www.amazon.co...m=ATVPDKIKX0DER
Tilt Sensor
Window Automation Sytem
http://www.amazon.co...=A18OY9PH6L0EN9
Programable Voice System
2x Mini Piezo Sirens (one for under the hood, one for in the car)
Universal Transponder Anti-Theft Adapter Bypass Wiring Kit
http://www.amazon.co...=A1729W3053T57N
I don't think i need a battery back up, because the stock battery is under my back seat, and i also have a battery bank in my trunk.
I will be having it all professionally installed, i just do not want to pay the prices at the store.
Let me know if this all works together!
Thanks fellas
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
Obviously i am aware that the Window Control Module and the Programmable Audio Module are additional features which are not necessary.
Bump.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
I guess my main question is this:
WTF is this thing for?
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
I replied like 2 days ago, but it never went up, damn, anyway, its to get past the cars security feature to make stealing your car harder, basically the car reads the keys signature that it emits within a few inches, you program that module while it reads the key and tricks the car to make it seems as if the key is next to the ignition, so that it will start, otherwise if the remote start went to power up the ignition, accessory and starter wires without that, it would think someone is trying to hot wire the car cause it doesnt see a key, as for your other features, I would skip the voice module, as it seemed cool to me when I wanted to get it at first, but then you realize that its kinda cheese, and like 1980's kind of feeling, ill link a video that makes you change your mind, ha ha, also the best sensors would be the glass break sensor, and the doors, which is built int, I dont like shock sensors, seem to be kinda qimmicke, cause a lot of pros dont have to use force to break in a car, only people new to the task of stealing, but then again, you may get someone like that trying to break in, from what I can see everything you listed looks good for what you need, I didnt check to make sure that is the right bypass, but if it lists your car then you are fine. also not all cars need a bypass, you can look it up to see if you need one, or ask the shop to see if they can, but it online though, it will be gobs cheaper
After watching this video I did not want that voice module, ha ha
idk, but I would feel embarrassing to have that, if you have any other questions, just ask
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Dear God... Thank you for showing me that video, lol.
No way in hell will i be getting the voice module, haha.
Just making sure i understand your post... the 5902 has built in "door security", no additional accessory is needed for that? And the shock sensor comes with the unit.
Also the audio sensor and the tilt sensor are things you would recommend?
And on the viper website i "built my system" and it recommended that bypass for my vehicle, so I'm assuming it will be needed,
Thanks!
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
Thanks!
haha, I am glad you watched it, sounds cool in theory, when in real life the voice module is retarted. Yes the door triggers come with it, and the shock sensor is built into the unit, really the shock sensor is useless, either the door or glass break will pick up a break in. For sure get the glass break sensor, comes with a mic to listen for glass breakage, and the tilt sensor only if you have rims, or your worried about someone stealing your vehicle with a tow truck. :D
Pioneer 4300DVD
