Some amps have a switch to combine the signal for the 4 channels, so you would only need 1 set or RCA's, though this is mainly ideal if you are running multiple sets for the front stage, at least thats how my PPI Art is.
¿ǝɯɐƃ ǝɥʇ
that should work fine. as long as your below the ohm limit you'll be good
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Yea i got all that but i was told yes that i could hook two speaker wires to ONE TERMINAL WITHIN ONE CHANNEL
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
you would have to wire the speakers in parallel if i recall correctly.
i only have 2 sets of preouts on my headunit, one set is going to the sub amp, and the other set (front) is going to my 4 channel. i just put it into the front rca inputs on the amp, then took a short run of rca's and plugged them into the rca output and then plugged them into the rear input. has been working fine for WELL over a year
To be honest Kranny i didnt get that... LOL plugged the short RCAs into what RCA out if both are being used?
sounds like he plugged the short rcas into the preamp out on his bass amp then ran it into the other rcas on his 4 channel
