went to hook up my amp today and only lights kicking on are the accent lights on the amp. no power light no protect light. its a autotek mm 4000.1 the old school one. i checked the ground its good the amp is getting power at the connectors. i also unhooked the rca's and still nothing please help.
Team DBs (Driven By sound)
is there no signal coming from the amp with a sub hooked up? maybe the led light burned out? seen it happen before but if not idk broski lol
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
nothen at all no noise no nothen even took the amp out and help it upside down to see if something inside came loose and nothen rattled.
i have an older 1000 1.d and have had the same problem, i attempted to repair it my self, i have some skills in soldering and knew of place to get the parts, when it came down to it my caps were fried several mosfets and some other parts, spent maybbe 13 bucks on all the parts, when i got to the end theres a module board in there that needed some repair also i attempted to fix it seem to have went well, all in all i failed , needless to say everything from a visual perspective looked new, should have kicked on, but no thats not the case, with out an oscope and the right knowledge to diagnose problems unseen, its a lost cause, being those amps dont cost very much it wasnt worth the money to have it shipped and repaired, would have been more than the amp was brand new, it just an opinion but its most likely time to purchase a new amp. good luck
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
have you tried hookin your Ipod directly into it to see if it works
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
it doesnt power up only thing that works is the logo and accent lights thats it
damn! well idk sounds like it needs to see a doctor
big 3 1/0
