What size Fuse
Im going to give myself a headache trying to understand fuses. Let me see if i got it straight.
For instance my sax-1200d has 3 of those tiny 40 amp fuses in it already. If i put an anl fuse between the battery and the amp, its like extra protection right? If so does that mean i should use a 90 amp fuse, bigger, smaller? For the love of god help me understand.
If I'm goin to hell, I'm going in a HOLDEN!!!
Speed doesn't kill, Its the stopping suddenly that gets you.
Quoted by the one and only Jeremy Clarkson.
Build: A Secret!
this is nto as hard as you are making it to be. the fuse is in the power wire to protect the wire. you should normlaly fuse it to the max rating of the wire. for instance a 1/0 run of OFC over 15 feet is 300 amps. you fuse it witha 300 amp fuse. I dont think fusing with 90 amps is a very good idea when your amp is requiring 120 amps.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thank you so much, another thread was screwing with my head saying using less was better. You Sir are mad :good:
Edit:Is it better to use a slightly higher rating like if its 120, use 135 amp fuse instead, or use a lower sized fuze.
Build: A Secret!
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
