i was under the impression the big three meant alt, wiring, and bettery
am i wrong?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
yes... chassis to engine block..
although i did try this step it did nothing to improve my voltage so i didn't do it...
but the other 2 really helped with dimming and voltage problems.. :)
not etirely sure how that worx
but if people do it then i guess it worx
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
its basically just a bolt on the engine...
but don't use ones that are important like ones that hold a gasket or something
hmm so can u explain to me in great detail wut this does and wut to do
cause it makes no sense to me
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
you take big wire 1/0 guage or w/e you're gonna use.. run it from the alternator to the battery
then take some more wire run it from the battery to the ground
then from your engines ground to the chassis
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
basically get a bolt thats on the engine... remove it... sand the area until shiney and dirt-free... add 0 gauge ring terminal... and ground the sum bitch :)
*edit*
http://www.caraudio.com/forum/showthread.php?t=152355
here is a link where they show you how to do it all !!!!!!!!!!!!!!!!!!!!!!!
Edited by Coolwazabi
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
