ok so i have a walmart battery that doesnt have + and - terminal screw things on the top would i be able to put some on the sides and cut/strip the wire back on the + and neg going to my battery right now and connect them to a neg and pos terminal? if u dont get what i mean ill get some pics... ill get them now just incase
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
Yea idk what exactly you mean pics would help.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
bettery is like this
wires r like this with another wire coming out of the power and 2 negatives coming out of the negative that r grounded to my car
positive wire is running off of that little gold screw on the top.
but isnt there a negative coming from the alt too? or not
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
No the alternator does have a ground wire it gets grounded by the engine. And any positive or negative terminal on the batt can be used as long as its the right one
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
You need something like these
http://www.darvex.co...inal-14p241.htm
and with that i just replace the bolt thats in the wire holder right now? and then just get a end on the 0g and put it around that bolt and tighten down?
and wats a site that has some cheap 300A 1/0g fuses and some cheap 150a 4g fuses and wire
Edited by HotRodHam
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
That would be fine
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
O and knuconcepts is prob got the cheapest wire
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Same site I showed you has fuses too
found it... but i didnt expect fuses to be that expensive haha. pretty sure the electrical is the part of the system that will run u about the highest
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
