RooTxBeeR Posted April 4, 2011 Report Posted April 4, 2011 I have 2 JBL GT100d's running in series on 425 watts, from a MTX Road Thunder. I currently have a sealed box, but would like to make a ported. In the owners manual for the speaker there is a box design for 35Hz. I have all the data for the sub also. Does anyone know of a box design that would possibly be better than the one in the manual? DIAMETER: 10" (254.0 MM) SENSITIVITY (2.83 V @ 1 M): 94 dB POWER HANDLING: 260 WRMS FREQUENCY RESPONSE: 30 ~ 3,500 HZ NOMINAL IMPEDANCE: 4 OHMS (PER COIL) VOICE-COIL DIAMETER: 2.0" (50.7 MM) THIELE-SMALL PARAMETERS* VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 1.54 VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH). . . . . . . . 1.22 DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 54.78 SD (CM2). . . . . . . 355.00 MOTOR FORCE FACTOR: BL . . . . . . . . . 7.22 COMPLIANCE VOLUME: VAS (FT3). . . . . . . . . 2.63 VAS (LITERS). . . . . . 62.10 SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 443.54 MOVING MASS, AIR LOAD: MMS (GRAMS) . . . . . 74.66 MOVING MASS, DIAPHRAGM: MMD (GRAMS). . . . . 71.46 FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 27.66 MECHANICAL Q: QMS . . . . . . . . . . . 10.98 ELECTRICAL Q: QES . . . . . . . . . . . . 0.38 TOTAL Q: QTS . . . . . . . . . . . . 0.37 MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 0.31 HAG (MM) . . . . . . . . 7.92 VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 0.88 HVC (MM) . . . . . . . 22.23 MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.28 XMAX (MM). . . . . . . . 7.15 On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
